Old 08-20-2012, 07:02 PM   #1
TheGammaGhost   TheGammaGhost is offline
Oh yeah, im thinking/hoping more and more its the CDI.
Clutch problem I caused Must have been in the Engine, but yeah, it would be WAY easier if we we're all able to hang out and solve these problems. Would be awesome to know some Smart Folks like you guys.
A stroke, damn. My bike problems are TINY compares to some crap like that.
Thanks again!
2021 Boom Vader Gen 2 BD125-10 Current
2011 DRZ400S Current
2006 LIFANIZED ROKETA DB-06 200cc Sold
2008 Ninja 250R Sold
1984 Honda aero 125 Sold
1980 Honda CM400T Sold
Old 08-20-2012, 07:22 PM   #2
Ok, take a deep breath. We'll figure this out.
First of all, the bike isn't like to even kick start if the battery is dead. Give it some time on the charger.
Second, the extra wires from the stator are likely for an LEZD gearshift indicator. Kato can likely confirm that.
Before you try anything else, please tell us exactly how you were checking for spark. Pretend that we know nothing about how to do it.
Old 08-20-2012, 07:33 PM   #3
k
I took the spark plug out, then re attached it to the coil/spark plug cord. then i made it so the bolt part of the spark plug, was touching my engine, and then i kick started it. Got no spark, did i do it properly?
Old 08-20-2012, 07:45 PM   #4
Yes, but only if the surface you held it against isn't painted. Sometimes you need to try holding it against a bolt head. Please try that and let us know.
Make sure you're in the shade for the process.
Old 08-20-2012, 08:41 PM   #5
katoranger's Avatar
I am no expert, but it sounds like the wiring at the CDI may be different. It will be a matter of matching up wires. I would first try swapping CDIs.
We need WA for this. GY5 Guru.
Don't worry. It will work. It is just a setback.
Pictures will always help.
Old 08-20-2012, 11:10 PM   #6
Wild_Alaskan's Avatar
first off the thing on the rear sprocket on the gy5 is a circlip, you need special pliers to spread the gap on it and it will come off. you dont even need to remove the four bolts they are just drive pins. Also the way these rear wheels work on these is an absolutely horrible design in my opinion so you may be best off just getting a longer chain or differnt front sprocket or whatever you need to make your stock rear wheel work for you.
The connector you are looking at with about 6 pins id the gear indicator connector, Im guessing yours had a neutral switch or indicator and that's why it only had 1 wire. the only thing that it could effect is whether the e-start will work in neutral with out the clutch pulled. but it sounds like you got the e-start working so that plug in is likely not the problem.
Do the wire colors of the main connector match up? don't start chopping stuff up just yet.
and more pics the better :wink:
Old 08-20-2012, 11:23 PM   #7
do you have a wiring diagram for your rocketa?
Old 08-20-2012, 11:33 PM   #8
I refound my photocopy of the lifans wiring diagram, i even had put the colors on parts of it for when i was swapping to a 400cc
Its too big for the forum but heres a link
http://i1154.photobucket.com/albums/...grahmlifan.png
again do not start chopping stuff up unless you know you can put it back right
Old 08-21-2012, 12:55 PM   #9
Ill take some pics of both cdi's and there cables, for further guidance, i dont want to mess it up.
and no i dont have a diagram for my roketa, ill search around.
BRB with some pics.
Old 08-21-2012, 01:18 PM   #10
bad quality
Roketa
Lifan
Roketa (notice the gap inbetween the two cables on the two prongs, if it wast for that, it'd fit right in. so to swap cdi's id need to use the Lifan male plug
Lifan
Lifan
Roketa
Old 08-21-2012, 01:20 PM   #11
It looks like its the same cords, but probably a different configuration, yeah definitively different config, do i just Pull them out of the male connectors? Ill be sure to take even better pics of both cord configs, before i do this. and upload them.
It looks like those green cords need to be in different spots.
Would just switching those cables around ( green, and green/white ) do it?
Let me know what you guys think!
Old 08-21-2012, 02:10 PM   #12
Hooper Imports used to have the wiring diagrams on their website but I can't find them now. Will look later if I get a chance. I think this is a simple wiring issue.
Old 08-21-2012, 02:13 PM   #13
Got it.
http://www.hooperimports.com/showpages.asp?pid=1013
I bet the answer is here but I lack the time now to interpret it. This may be what WA needs to solve the puzzle however. This is the data I used to wire my Lifan/Honda XR200.
Old 08-21-2012, 02:17 PM   #14
Nice, thanks Doc, i just made this on my lap top. notice the difference.
Old 08-21-2012, 02:30 PM   #15
Looks like the deal to me...
Wait until WA or someone confirms but it looks like you are two snips and splices away from riding enjoyment! :P
