Old 07-29-2013, 02:47 PM   #46
gagab1   gagab1 is offline
yes... i try with 3 different ingnition coil
. I think i have a ground problem... but i test all the ground connection with a multimeter...
Old 07-30-2013, 10:37 AM   #47
So i figured out the problem i had a bad connection on the wiring... but loll i have 2 coil one not work at all and the other make 1 spark at 10 flywheel loop.
this is shwit
Old 08-13-2013, 12:08 AM   #48
oviking99   oviking99 is offline
Originally Posted by gagab1 View Post
yep the throttle cable is backward... i made other test. The cdi is good and the plug geos to the coil is good but when en connect the plug with the ignition coil. Nothing happens... no spark i test it wiht a power supply and the coil make good spark.
At this point i'm a little bit screwed.
Not sure what coil you are using, but it sounds like the 2 wires to the coil may be reversed.
