#46 |
The first pic shows the adjustment. It pulls the rear of the engine up and down. Somewhat of a T-bolt that mounts to the rear engine mounts. I think the rear of the engine needs to shift to the left about 1/16 to 1/8 inch.
#47 |
Do you really need two drive chains? Perhaps you can move the outer, counter shaft sprocket closer to the engine a bit, and just use one drive chain on both outer sprockets?
#48 |
Spud, I have been thinking the same thing. One #50 chain should be strong enough for the job.
#49 |
I bet one drive chain will work just fine, especially at lower speeds. In any event, it's certainly worth a try.
#50 |
Consider it your first performance mod. Less rotating weight.
Happy to serve. |
#51 |
I don't know why they used a double row chain. Not that much power being made.
#52 |
I was thinking the same thing. A lot of rotating mass for 150cc.
#53 |
After I get the sprockets lined up I think that I will buy some single #50 chain.
#54 |
Any progress on the buggy Kato? Neat looking rig!
#55 |
We just got back to KS. All the parts are in so tonight or tomorrow we should be able to put it back together.
#56 |
Last night we installed the new yellow clutch springs, belt, and the variator with 8 gram sliders. Took it out for some after dark testing. CVT works much better.
Today we modified the chain adjuster/mount. I cut off an 1/8 inch of material so that the rear of the engine could move over. This helped alot. I think I need to take alittle bit more. Pictures and video on the way. We have put about a total of an hour run time. About 3/4 gallon of gas used.
#57 |
Pics of the new yellow 1500rpm torque and clutch springs. The exhaust mount that lost the nut on the inside of the cover. I used the impact to tighten it back up. Emilie with her helmet.
#58 |
Chance of snow tonight.
#59 |
Thanks for the update, Allen!
![]() ![]() Did you get Emilie's helmet at Target? I know they sell helmets. ![]()
