#46 |
azh...stock led turns, nice. that durn running led light bulb is nice and crisp white, thought it was the head bulb in the pic. keep up good work. remember watch your pennies, dont get carried away. your one of the good posters, dont blow your cash too quick before you get the rx3 , (i know you were eyeballing them on last weekends ride
#47 | |
![]() While I was bored today I decided to take apart and check on the sizes of Jets in the VM26... it came with the standard 100 main and 20 slow... still waiting on the Main and Slow jets I ordered from China, I'm thinking a 105 main and 22.5 slow will be a good starting point for tuning, doubt I will need much more of a slow jet as the Pilot Screw is already at '1.5 turn out' (about the perfect size, anything over 2 turns needs a bigger jet). I weighed the stock exhaust and found out it's too darn heavy! Stock header is just shy of 6lbs ![]() ![]() if all goes well I will have it down to, 1.2lbs for a FMF PowerBomb Header and a massive 2.6lbs for the muffler ![]() ![]()
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#48 |
That other thread got me thinking azh, seem like you could also save a lot of weight with one of those lithium batteries over a lead acid battery.
#49 |
Just placed an order for a performance exhaust header and a Honda Copper/Crush Exhaust Gasket, will let everyone know how everything works out in a few weeks time when it all shows up
#50 |
A pic to see how restrictive the stock exhaust is, a US quarter wont fit and there is a nickle missing from the pic, it barely had enough room and slid down into the exhaust just before I snapped the pic
#51 |
Do you know the new inner diameter of the headder? If yes, what's it's relation to that quarter (new headpipe).
#52 | |
#53 |
I thought of doing that 2LZ , maybe if the Header Weld on the inside was the only problem and restriction with the Header (like on Suzuki DRZ400) but it's not
#54 | |
I have the TT250 coming and I'm really looking forward to what header pipe some folks here are trying. I want to dump the cat before anything else.
#55 | |
2005 CBR600RR
2016 CSC TT250 Coming Soon Last edited by ughmas; 04-18-2016 at 12:50 PM. |
#56 | |
#57 |
Ahhh man! I wonder if part #4 "Muffler is the front"
![]() ![]() ![]() I might order one (when the show up in May) just to try it out, it will give people a less expensive option to upgrade their Header pipe and drop all those 'Eggs, Baffles, and horrible welds' on some of these Bashan's ![]()
#58 |
A few measurements I collected on the stock exhaust:
Nickle used (missing from previous pic): 21.28mm Quarter used (shown in previous pic): 24.19mm 'Spring/Coil/Soda Can' Exhaust Gasket... ![]() ![]() Header Weight: ~5.98lbs (5lbs 15.7 ounces) OD of Header (Engine Side): 39.11 - 39.24mm ID of Header (Engine side): 21.35mm (worst welded spots) - 23.58mm (largest opening of welded spots) ID of Header (Muffler side): 26.51mm all around (was wondering about that exhaust leak!) Muffler Weight: ~12.43lbs (12lbs 6.9 ounces) ID of Muffler (Header side): 27.11mm (was wondering about that exhaust leak!) ID of Muffler (Exhaust Tip): 19.78mm So you can see how futsed up the stock exhaust is on (this) Bashan moto ![]()
#59 |
New parts are in
![]() ![]() ![]() New Honda OE Exhaust Gasket: ID: 31.5mm OD: 39.8mm New Exhaust Header: Weight: under 1.25lbs ![]() ID at the Engine/Exhaust: 28.76 - 28.80mm ID past the weld: ~31mm+ all round OD at the Engine/Exhaust: 38.02mm ID at the Muffler Side: ~31.56mm all round OD at the Muffler Side: ~34.49mm all round FMF Turbinecore Universal Muffler: Weight: ~2.9lbs ![]() 'Universal Mid Pipe' ID: 29.29mm all round on one side 'Universal Mid Pipe' ID: 31.45mm all round the other side Now I just have to make it all work ![]()
#60 |
Considering what you stripped out of your kawasaki 650 I would expect nothing less from you on this WILL bike .. kinda like the Oprah diets for duelsports.
