05-01-2020, 09:52 AM | #46 |
Has anyone tried the luggage rack on a Hawk and does it fit?
https://shop.brozz250.com/eshopprod_...ggage_Rack.htm |
05-01-2020, 02:46 PM | #47 | |
https://store.cscmotorcycles.com/BLA...p/csc-6000.htm You could also just search Hawk 250 luggage rack on google and refine it for chinariders.net results. There has been a few posts by guys who have done a few DIY racks over the years, and I think one guy who mounted a GIVI top boc mount directly to his Hawk.
05-12-2020, 04:48 PM | #48 |
I'm getting ready to install this on my TBR7 , anyone done it yet, any known issues?
2020 TBR7 2020 Apollo x18 2009 KLX250s 2016 CB300F 2017 Harley street 750 |
05-13-2020, 04:25 PM | #49 |
I'm doing mock up on the TBR7 and found I need a caliper mount from either the Brozz or Hawk, the diagrams I'm finding show the drum brakes. Anyone know where I can find one?
I went with a 280mm shock, the stock was 305mm, it seemed to end up maybe an inch shorter.
05-13-2020, 04:29 PM | #50 | |
05-13-2020, 04:48 PM | #51 |
Yes I bought the kit. My bracket is totally flat, and used a small spacer between it and the wheel before, plus the caliper locating pin was a little longer. With the required spacer to line up the caliper with the rotor, it's about 3/8 inch away from the pin. Looking at your pics it appears that the one you are using has some offset with the spacer built in.
05-13-2020, 05:17 PM | #52 |
Looks like you have the spacer on the wrong side.
05-13-2020, 06:07 PM | #53 |
The spacer that was included with the kit is installed on the other side, it's a bit bigger. I then had to use the stock spacer from that side on this side to make things line up. The wheel is centered and the chain is straight.
If you look at post 22 in this thread it shows Dans bracket, with more of a built in spacer .
05-14-2020, 01:30 AM | #54 |
Yeah, I couldn't find much in terms of pictures of the TBR7 setup from any different angles, but if it has a separate spacer and the bracket itself has no channel, you may have to work out if a Hawk or Brozz bracket and caliper will be a viable solution for you.
I can try to match up some measurements with you to see if the Hawk bracket might be an option. If the rotor is offset the same from the hub then it should be a non issue. When I get a chance I will measure how far the rear disc is from the inside edge of the swing arm. If that matches up, then the Hawk bracket and caliper should work.
05-14-2020, 07:49 AM | #55 | |
05-14-2020, 08:08 AM | #56 | |
05-14-2020, 10:21 PM | #57 | |
You may need a CSC Hawk etc rear mounting bracket thats got an offset |
05-14-2020, 10:22 PM | #58 | |
Maybe you can weld on the steel plate to catch the locating area on the swing arm? |
05-14-2020, 11:00 PM | #59 |
I thought about the welding little "angle irons " on to the plate, but then thought just a little rod/ shaped bolt, welded on to the swingarm locating pin would probably work also. It's gotta go to my buddies to weld, so I'm still hoping for an easy bolt on solution. The caliper itself has a stop built in that rests against the swingarm. So the only real pressure is when hitting the rear brakes going backwards. If I needed to ride it, bailing wire would ease my mind enough to ride it.
05-14-2020, 11:08 PM | #60 |
I get back home tonight, I was out of town at another facility for my company.. I will measure it as soon as I get a chance
