Old 09-27-2022, 03:48 PM   #1
Originally Posted by Huck369 View Post
I may have found the fix for those of us having issues with the rear brake, I took the rear slider bolt off, and left the lock washer off, and reinstalled with lock-tight, the Lock washer was causing the caliper to not have enough space, removing that lock washer made it work as it should.
PS, the headlight sucks, I'll end up adding some Aux Lighting
Confused about what you did. Any pics? How would it be better than adding a large washer inside the swingarm after the brake stay?
Old 09-28-2022, 07:07 AM   #2
Huck369   Huck369 is offline
Huck369's Avatar
Sorry, didn't think to take pics.....if I get time I might try to get some later....
The caliper is mounted off a spacer on the axle, not off the swing arm, and the rotor is mounted off the wheel, so adding the washer by the swing arm doesn't affect the spacing of the caliper, with removing the lock washer from the rear slider pin it allows the caliper to move the thickness of that washer further toward the wheel, which is where it needs additional space, the front slider is made differently, and has the extra clearance already.
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2021 Moto Guzzi V85TT
2021 Sondors Metacycle
AMA Life Member
Old 09-28-2022, 01:49 PM   #3
JRust   JRust is offline
I will have to try the lock washer removal. I agree that adding a washer on the swingarm side of the brake mount should not affect the brake position relative to the rotor? They are still mounted against each other.
Old 09-27-2022, 05:13 PM   #4
clezummavrider   clezummavrider is offline
This is awesome, will make the change and keep the washer for best of both worlds, at least on my bike the rear swingarm is not aligning in parallel to the face of the axle spacer so the washer helps mitigate some of the angle.
Old 09-29-2022, 05:58 PM   #5
I need a little help. I messed up a few of my rear spoke nipples trying to true my wheel. I’ve been to 3 different local shops trying to get replacement nipples with no luck. All the ones they have are too small. Anyone know what size I need and where to get them?
Old 09-29-2022, 07:05 PM   #6
Contact PSM. No kidding. They have a line to Zuumav.
Old 09-29-2022, 08:26 PM   #7
Do you have a contact?
Old 09-30-2022, 08:04 AM   #8
parts for Templars
service@maxpro-llc.com
Tell them the model number. They have the wheels (laced, with hub, bearings and seals) as well.
Old 09-30-2022, 09:00 AM   #9
Thanks. I am emailing them now.
Old 09-30-2022, 03:42 PM   #10
chinazuki   chinazuki is offline
when checking/adjusting valves....is there a TDC mark, or pull the plug and watch the piston/valves?
....bypassing the brake switch on starting (to allow push start) has that been done?
arkansas
Old 10-01-2022, 10:52 AM   #11
Hap   Hap is offline
I don’t know. But that’s a good idea. Without a backup kickstart.
Old 10-01-2022, 03:58 PM   #12
Yes, it’s on the left side of the engine.
Old 10-05-2022, 12:15 PM   #13
Help! Despite having opened up a few of these youall tamper proof carbs on other bikes, this one wound up being a fail due to the screws being red locktited in, i wound up having to break the bowl off and now need to order a replacement. Which one for the Templar X (6-speed) a PE28 or PE30. I already have the 125 main and 42 pilot i plan to use. Thanks
Old 10-05-2022, 08:47 PM   #14
defeating threadlocked carb bowl (Youall smoothbore on Temp X)
https://www.chinariders.net/showpost...09&postcount=7
I posted the solution for this. It is #7 in
https://www.chinariders.net/showthread.php?t=31439
in the Video and Pics section.
Grind off the head, bowl comes right off...then the stem of the bolt is easy to extract. Yes, it has threadlocker, but still comes out.
Old 10-06-2022, 03:45 PM   #15
I was also surprised by the red loctite on the carb. I ended up grinding off the top of the screws which allowed the bowl to be removed. I then used some vice grips to unscrew the studs. Replaced them with some screws from the hardware store.
