#61 |
Nah, not yet anyway. Probably just a cheap digi speedo for now.
#62 |
Made some more progress today.
![]() I re-wired an atv keyed ignition to work with the TW harness, connected a battery and it turned over upon hitting the starter button. Even better, it makes spark! ![]() I added an electronic flasher from NAPA, and I connected the LED signals and tail light I picked up on eBay. The tail light works great, but the signals just pulse right now; I think that will change once an indicator light is added. I have a new air box tube on order from Bikebandit, so I should be able to try and start it soon. My good friend Spud is sending his Zong tank, and I'm hoping that it will be a close match. I learned from a TW forum that the speedometer needs to be a 2240:60 ratio, which I think means the speedometer gear is turning at 2240rpm at 60mph. I converted that ratio to metric and was pleased to find a small, cheap white faced speedometer on eBay that should do the trick: Universal Dual Odometer Speedometer The price is right. Once it runs, I'll start buying stuff for it. I need to find something to make the fork tubes a little thicker, so my new Acerbis headlight will attach properly. I'll see if I can find some ABS or PVC pipe that will do the trick, or I'll get some stainless tube. I'm also hoping I can find a cheap super moto front fender and 428 chain at Gnarly Parts. I've found a cheap seatcover on eBay, some high bend atv bars at rockymountainatvmc, wide foot pegs on eBay and tapered steering stem bearings on eBay. I've also learned that a Yamaha blaster shock is two inches longer than stock, but it bolts in to give a higher seat height. I can't wait to start this bike. ![]()
#63 | |||
![]() Quote:
![]() Quote:
![]() ![]() Spud ![]()
#64 |
Great work Weld, and a great assist from Spud. Great people here.
You've made a lot of progress and have really done your homework. I'm impressed!
Happy to serve. |
#65 | |
Thanks for offering to ship the tank, Spud. Don't worry about the quote; I'm sure you'll find a cost-effective method to Sumas, WA. I'm ready for the tank now, so I'm not too worried about cost.
#66 | |
#67 | ||
Spud ![]()
#68 |
I responded to you by PM, Spud.
#69 | |
![]() Spud ![]()
#70 |
I love that
![]() You have job to do on it ... |
#71 |
Thanks for your response, Philamiens. You are correct, I have a lot of work to do, but I think I am in the middle of the project. I hope to have the chance to start it soon.
#72 |
This would be why I was unable to connect the carb to the airbox; the original air tube shrunk by 1/2". The new air tube is much softer and easier to work with.
#73 |
Unfortunatly shrinking can occur with aging.... :roll:
Happy to serve. |
#74 |
Hmm maybe I should buy a new one for my 78 DT175. It still connects but it is a bear to get on and off. But most likely they are No longer available.
#75 | |
