Old 02-22-2013, 11:49 PM   #61
Sounds like an inadequate ground wire. A bigger ground wire is always a good idea.
Old 02-23-2013, 12:14 AM   #62
migue1760   migue1760 is offline
migue1760's Avatar
So i have to replace the whole battery ground wire, the battery was discharging and didnt crank the engine nomore and smoke came out from under the seat, i checked and it was the wire and maybe the battery that smoked, were can i get the exact back wheels cheap for my quad because i messed one up
Old 02-23-2013, 03:51 PM   #63
I'd look on eBay.
Old 02-23-2013, 07:21 PM   #64
migue1760's Avatar
Why does my quad back fire when it decelerate?
Old 02-24-2013, 05:45 PM   #65
It's a little lean. I'm not exactly sure which circuit in the carb would be responsible, because it depends on whether you still have the throttle open or it is fully closed. I would move the jet needle clip down one notch and see if it goes away.
Old 02-24-2013, 06:54 PM   #66
migue1760's Avatar
Well i fill up the gas tank half ways and it eats it up quick and i moved all the screws when the quad was on and when i accelerate it lags for a little while and then goes and when i let go of the gas it starts backfiring like 1 or 2 times, another carb clean? Readjust?
Old 02-24-2013, 07:04 PM   #67
Again, I'd move the clip down one notch.
Old 02-24-2013, 08:13 PM   #68
migue1760's Avatar
To give it more fuel?
Old 02-24-2013, 08:30 PM   #69
migue1760's Avatar
Weres the clip?
Old 02-25-2013, 12:13 AM   #70
The clip is on the jet needle, which is within the slider. If you unscrew the top cap of the carb and remove it, you'll see the needle. Search the forum for carb tutorials.
Old 02-25-2013, 01:33 AM   #71
migue1760's Avatar
I got it, so basically im moving the neddle down a notch?
Old 02-25-2013, 10:38 AM   #72
Correct.
Old 02-25-2013, 02:27 PM   #73
migue1760's Avatar
Im going to put it together and ill tell you if the backfire goes away
Old 02-26-2013, 12:00 AM   #74
migue1760's Avatar
I fixed it but i think it gets air an revs byitself but doesnt backfire
Old 02-26-2013, 12:49 AM   #75
I encountered that once before. See page 4: http://www.chinariders.net/modules.p...r=asc&start=45
That page will also give you some jet info.
