Old 12-12-2013, 11:10 AM   #61
They can always ask, but it's not likely that they'll get $350 for a China buggy with no forward gear.
Old 12-12-2013, 11:16 AM   #62
katoranger's Avatar
I am not going to pay that. Thinking about $200. They still have it and its been a few weeks since saw that ad.
Old 12-12-2013, 11:18 AM   #63
What is it powered by? I have some horizontal motor stuff that you're welcome to. Perhaps enough to fix the forward gear issue.
Old 12-12-2013, 11:20 AM   #64
katoranger's Avatar
I believe it has a 150cc GY6. Not sure on the forward/reverse setup yet. Trying to research it. Also need to measure the big blue van to see if it will fit in the back.
Old 12-12-2013, 11:22 AM   #65
Good score, if it's a GY6. The planetary reverse setup is still available online, and it bolts to the output shaft, right where the rear wheel bolted on your Elite.
Old 12-12-2013, 11:23 AM   #66
katoranger's Avatar
I think finding the parts will be easy. My plan is to go will some cash and see what they say.
Old 12-12-2013, 11:54 AM   #67
katoranger's Avatar
Its possible that something simple is broken or stuck. My be a zero dollar fix.
Old 12-12-2013, 01:02 PM   #68
katoranger's Avatar
Similar buggy.
http://buggynews.com/carter-talon-dl...up-t40930.html
Old 12-12-2013, 06:52 PM   #69
katoranger's Avatar
My wife didn't balk. Plan is to go look tomorrow night. Its about 30 minutes away.
Old 12-12-2013, 07:56 PM   #70
Good luck, Allen.
Old 12-12-2013, 10:18 PM   #71
katoranger's Avatar
Need to fill the van up with oil for the trip. Thinks its a 2 stroke.
Old 12-12-2013, 11:08 PM   #72
Old 12-13-2013, 12:43 AM   #73
I love it when the CFO is in a good mood.
Old 12-13-2013, 01:39 PM   #74
katoranger's Avatar
I only plan to go with $200. We will see if there is any room to negotiate.
Old 12-13-2013, 08:10 PM   #75
katoranger's Avatar
Back to China riding. One Vision Razor z2150r buggy made the trip home in the back of the van. I showed up and it started right up. Everything works. ( I even got it to go forward.) $320 with new battery, sparkplug and air filter. Has aluminum wheels and good tires too.
He took the cage off to fit it into the van. We took it for a rip around the yard. I think the CVT is sticking in a higher ratio. Not much low end grunt. The cable for the shifter is stretch and needs adjusting and the positive battery cable terminal is loose.
Lights and horn work.
I think I will start a new thread on this buggy.
