Old 05-23-2015, 11:47 AM   #61
katflap   katflap is offline
katflap's Avatar
Thanks to the posts in this thread I have now adjusted my rear shock. A definite benefit to the ride feel.
loosened off 1 1/2 turns , think I need to up my pie intake
Old 05-23-2015, 11:50 AM   #62
Good for you, Kat. Thanks for letting us know the results.
Old 06-03-2015, 09:37 PM   #63
woodlandsprite's Avatar
so...what is the slow/fast dial on the bottom of the shock for - does it actually adjust the rebound damping of the shock a noticeable amount?
Old 06-03-2015, 10:37 PM   #64
Yes, the screw at the bottom of the shock absorber is used to adjust the rebound damping. Turning the screw counter-clockwise allows for less damping, and a faster rebound. Turning the screw clockwise allows for more damping, and a slower rebound. The rebound damping of the RX3 shock absorber has 16 positions, and works well. Adjusting the screw does result in a noticeable difference in rebound damping.
Old 06-08-2015, 07:22 PM   #65
fishman10's Avatar
adjusting rear shock spring
i got lucky,,the locking collar with the set screw was facing foward,,,so after removing both side panels i was able to reach in with a small ''L'' shaped allen wrench and loosen the set screw.Oh forgot to mention bike was up on the centerstand,,,,at this point i was able to just reach in and turn the collar counterclockwise loosening the spring ,as i thought it was much too harsh.Mine was set at about the middle of the of the threaded area. i could have loosened more ,,cause its slightly better,,but still not great.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 06-13-2015, 07:16 PM   #66
Hey AZRider George - hope you're still popping in here - do you happen to know what kind of shock spanner wrench you have? the one I bought is too big - and absolutely useless for trying to turn the locking collar on the RX3. While I had the side panel and seat off the bike earlier today to install a battery tender pigtail, I went ahead and loosened the allen nut and was able to turn the spring by hand to reduce the preload - I was not able to turn it to completely remove the preload, and I lost count of how many times I turned it because at first it didn't look like it was actually advancing the collar up the threaded shaft at all. I kept turning, hoping to get to 0 preload so I could try to start from 0 preload, but eventually got to a point where perhaps my hands fatigued out - or just got too sweaty (it was getting hot in the garage). There is definitely a lot more rider sag on the bike now....hopefully I didn't back it off too far :P In any case, in order to turn that locking collar I think I'm going to be needing a proper wrench - I think I'd rather go that route than a punch + hammer.
Old 06-14-2015, 12:10 AM   #67
AZRider   AZRider is offline
Sorry Sprite, but I don't have an actual size as I used the spanner from my Valkyrie. If you have a Cycle gear or similar store close by, ride the RX-3 there and have them match it to the bike. Most shocks on bikes are of a similar size, did you buy one intended for a car or truck?
George
2016 CanAm Spyder F3-L
Old 06-14-2015, 12:23 AM   #68
Thanks George - There isn't a Cycle Gear close enough for me to ride the bike to (still getting comfortable on the streets and cars around) - but I can drive my car to one :P
I suspect the one I ordered was for an ATV, though when I read the reviews, I thought I saw some folks mentioning it working for their bike(s)
ah well, maybe I will have lucked out and I have the spring set where I want it now - one could hope....
Old 06-14-2015, 01:01 AM   #69
Loosening the preload is easier than tightening the preload. Also, the job becomes much easier if you remove the rear wheel.
The space available for turning a spanner wrench is very limited. If you wear gloves and remove the rear wheel, I think it is easiest to turn the shock spring by hand. However, I own this punch and chisel set sold by Harbor Freight, and I have used it on the RX3 shock spring collar.
http://www.harborfreight.com/12-piec...set-66337.html
One of the small round punches perfectly fits the holes in the shock spring collar. You can insert this punch in a hole, and use the punch as a lever to turn the shock spring. Also, you can easily turn the collar by striking the larger pencil punches with a hammer. I can affirm the pencil punches will not damage the collar.
Old 06-14-2015, 11:13 AM   #70
Maybe this pic will help.
File Type: jpg tmp_8545-20150614_080611-1286213300.jpg (94.4 KB, 327 views)
George
Old 06-14-2015, 12:47 PM   #71
That wrench is certainly short enough to fit in the limited space available. Thanks for posting the photo, George.
I don't own a shock spanner wrench; all the ones I have seen for sale are much longer than that wrench. I suppose one could also purchase a longer wrench, and cut it to the desired length.
Old 06-14-2015, 03:26 PM   #72
Indeed, that photo is helpful - unfortunately the 2 I saw on the cycle gear site seem like they might both be too large.
Old 06-14-2015, 05:07 PM   #73
Seriously, I did test the Harbor Freight (HF) punch and chisel set mentioned in post #69 of this thread. Both the round punch and the pencil punches worked well, and neither damaged the locking ring. However, I abandoned the punches when I discovered it was much faster for me to turn the shock spring by hand.
Old 06-14-2015, 08:43 PM   #74
thanks spud. That may be the route I have to go since I definitely can't seem to turn the spring to tighten it by hand
Old 06-16-2015, 02:41 AM   #75
rjmorel   rjmorel is offline
rjmorel's Avatar
Of course, one can also install the CSC centerstand. However, I have heard it takes a good bit of upper body strength, and a strong back, to get the RX3 up on that centerstand. Since my aging back has seen better days, I would rather let my Husky jack do all the work.
Spud, here's what I did for my aging back to get it up on center stand easier out in the field.
http://www.chinariders.net/showthrea...d=1#post187142
The Husky jack would be more challenging to take out on a ride I must admit, rj
