Thread Tools Display Modes
Old 11-06-2016, 06:59 PM   #61
Originally Posted by Azhule View Post
No arguments from me use and pay for whatever you want, I'm just listing an inexpensive alternative to what you may be using... no need to get all "Bob the oil guy" on a ASE cert. tech funny threads over there... always find the dreaded "I put X oil in my engine/transmission and it threw the timing belt into the gas tank, and that angered the unicorns in my muffler who drained my blinker fluid" kinda threads...
I've talked to countless "Master Mechanics" over the years and they basically all say the same thing... "use what you want, as long at it meets your vehicles specs, the company paid a lot of $$ to put that spec on the label"... I doubt a name brand company like Havoline would lie about passing whatever they have on there label
Send off oil samples and see if the product is doing any harm or not
Havoline has done several Mercon tests and has the "pass/approval for use in" (directly from Havoline's website and bottle) :
Ford MERCON, MERCON V, MERCON SP and MERCON LV
Don't know why everyone jumps to arms over "oil"
As long as it full synthetic atf, Im sold.
Old 11-06-2016, 07:55 PM   #62
Landsvw   Landsvw is offline
Landsvw's Avatar
Yeah, I'm a fan of synthetic. Loved that Rotella T6 in my VW turbo diesel. I got synthetic from Walmart, their house brand, for the engine. And their house brand synthetic Mercon V too. I guess it's Supertech.
Anyway, today, my project was to install the intake manifold. I was examining the old one carefully, because it's plastic, and saw a problem. The aluminum crossover pipe gasket on the passenger side was blown out. So I opened it up. Not pretty. Plastic was broken around the inside edge. No gasket on that side, just filled with silicone.
I am now going to go back to the all aluminum non PI intake. I tapped and plugged the rear hole where the water line for the heater is. And, went and bought a fitting for the front, where a plug had been installed.
Ordered the older style gaskets as well. Glad I'm friends with the Napa guys...
This manifold has a weird electric flap built into the front of it. Anyone know what that does? My harness doesn't have that electric plug. Can't see it harming anything tho. Seems to redirect air through the giant plastic plenum, underneath the manifold.
Got the oil drained out of transmission pan, and new filter back in. Had the reusable gasket. That's a cool thing.
Ok, so 2 steps forward 1 step back, but a little further along. I am actually happy about the aluminum manifold. I've had to replace those plastic ones before, when I was working in a garage. Junk is what they are.
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 11-06-2016, 08:52 PM   #63
Landsvw's Avatar
Ok, so it's called the IMRC, or, intake manifold runner control. So, it converts the runners from long to short, and vice versa. It's naturally closed, so, I guess short runners. Sooo, now I have to figure out, is the engine going to run correctly with that closed, or should I put it in the open position? Hmmm... more complications...
1975 Corvette
2017 Chevy Bolt
Old 11-06-2016, 09:32 PM   #64
Landsvw's Avatar
Quoting myself again! Hahaha! Anyway, looks like mustang guys delete the thing. I may do that too, but will see how it runs first.
Ok, now I see it's actually called an Intake Manifold Tuning Valve. The PI engines didn't have it but the earlier ones did. Looks like some people are cutting the valve off and sticking the cover back on. I may do just that.
1975 Corvette
2017 Chevy Bolt
Old 11-07-2016, 12:23 AM   #65
Interesting concept, but I think I'd delete it.
Old 11-07-2016, 12:15 PM   #66
Landsvw's Avatar
Supposedly it stays closed to 2800rpm. Gives better torque at the lower
Rpm's. Then opens and gives better torque above 2800. But since I have no wiring for it I have to decide to have it open or closed
1975 Corvette
2017 Chevy Bolt
Old 11-07-2016, 08:12 PM   #67
Landsvw's Avatar
Woo hoo hoo hoo! Intake on! Alternator, radiator assy and a few hoses, And some fluid, and this thing should fire.
The aluminum intake was identical except for the rear heater hose, and the pcv vacuum port was slightly smaller. I modified my hose end and got it to work. I'm really happy that I have the aluminum one. Should never have any issues with cracking.
The IMTV worries me somewhat, but will see what happens. It should run great up to 3000rpm anyway. If it's weird above that I may have to take it out. I wonder if the computer has the capability to open it and maybe just a little wiring would make it work? I'll have to investigate pinouts.
1975 Corvette
2017 Chevy Bolt
Old 11-07-2016, 10:09 PM   #68
I think your making this whole thing up.
Pics?
Let's see those hands mister!
Old 11-07-2016, 10:29 PM   #69
Landsvw's Avatar
Pics?
Hahahaha, I wear blue nitrile gloves.. ok, ok, I'll get a few pics. It's hard to remember tho, in the middle of the project.
1975 Corvette
2017 Chevy Bolt
Old 11-08-2016, 02:27 AM   #70
Landsvw's Avatar
Holdover picture of old engine still coming out.
Will take a few tomorrow of the install.
1975 Corvette
2017 Chevy Bolt
Old 11-08-2016, 09:25 AM   #71
'16 TT250   '16 TT250 is offline
Maybe dissect or research to see if you can wire the IMRC actuator to a manual switch? Or maybe eliminate it and run a cable to control it? Or just drive it in each position and see which works better for you and leave it there.
Old 11-08-2016, 10:53 AM   #72
I've pulled engines with the dreaded green pistons as well.
Old 11-08-2016, 12:43 PM   #73
Holy crap, I take it back, no more pics (yuck)
Good thinking with the gloves, and the tetanus shot?
Old 11-08-2016, 09:06 PM   #74
Landsvw's Avatar
Plastic manifold blown out
Engine in place
A Chinese motorcycle and left overparts. Lol!!!!
Another engine view
Wait, am I supposed to have all of this left over????
And, as of 5pm a running truck! Drove around the block, no issues!
Updates tomorrow when I can top off tranny and anti freeze and then take her down the highway.
1975 Corvette
2017 Chevy Bolt
Old 11-09-2016, 01:19 AM   #75
Landsvw's Avatar
This truck must have had waves of muddy Texas river water cascading over its engine. There was also a legitimate rats nest under that manifold. Had my tetanus shot. I'm current.
1975 Corvette
2017 Chevy Bolt
