03-15-2020, 11:15 AM | #61 |
Wow, I definitely need to rejet. I could barely get 60 out of mine!
I’ll have about an hour free to work on it this evening. I wonder if that’s enough time for a carb newbie to get a jet swap done? Never mind. I found a good instructional video on YouTube and I’ll definitely save that for another day. I’ll just install the phone mount tonight. lol Here’s the clip for anyone interested. I believe this is the same carb on the X22R. Last edited by Chrisguga; 03-15-2020 at 12:11 PM. |
03-15-2020, 01:33 PM | #62 |
The rejetting is a must but also getting some miles on it and breaking the engine in. No need to shim the needle. Start with a 105 main and idle mixture 1 1/2 turns out from lightly seated. That should get you close. I'm running a 108 main but i did remove the cat. Now back to my regularly scheduled program for today. Back out for another ride.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-16-2020 at 08:44 AM. |
03-21-2020, 08:14 PM | #63 |
Even after replacing the starter on my riding mower, repairing my push mower and cutting my grass I still found time to swap out my carb to the PE30. The intake Herbie sent me wouldn't work so swapped intakes with the Hawk which fit better so all worked out. It took me a while to get it tuned. I started with a 38 pilot but would idle rough. I tried a 40 and a 42 and made no difference. I noticed if I shut off the fuel it would start running smoother and faster. Turned out the float was set too high so once I got that set the 42 pilot worked perfect at 1 3/4 turns out. I installed a 110 main and took her out for a ride. The engine will rev to 10k quick. Throttle response is so much better. I decide to take it out on the highway for about 10 or 11 miles. I was able to cruise between 70-75 mph easily. I took her up to 81mph briefly. Did I mention I love this bike. Lol
I also removed the air box and installed a Nibbi pod filter. I also hooked up the remote choke. That wasn't a direct fit. I had to cut the lead ball off because it was too big and I soldered a small ball on the end and is working so far.
03-21-2020, 09:57 PM | #64 |
The jetting is at least consistent. I can float between a 35 or 38 pilot depending on the air temps. I still think my jetting is thrown off by the longer intake I am using though.
So, without any head work, would you say the PE30 is a good upgrade?
03-21-2020, 10:10 PM | #65 |
Yes it's definitely an improvement. Much better throttle response.
03-21-2020, 10:10 PM | #66 |
Taking parts off the Hawk to make this bastard child run.. for shame for shame.. Jerry you know if you need any help or counseling I'm only a phone call away.
03-22-2020, 01:35 AM | #67 | |
Besides, it is hard to argue with how easy the idle mixture and idle speed are to access.
03-22-2020, 07:05 AM | #68 |
No shame here. I replaced the part with newer an better. the new intake fit the Hawk much better.
03-22-2020, 11:26 AM | #69 |
So is this intake, carb, and air filter setup what you’d recommend for this bike with head porting and shaving planned in the future?
Do you have links to all the parts? |
03-22-2020, 12:27 PM | #70 |
Yes this is the one. I bought the last one the seller had but will look for another and link it. The intake I robbed off my Hawk so I would have to find another link to that one too.
03-22-2020, 12:34 PM | #71 |
Here's the intake.
https://www.amazon.com/dp/B01FAGIS7U..._gk5DEbF8Z89TV Filter. https://www.amazon.com/dp/B074SKBZ3S...p_mob_ap_share This is the carb I ordered but was sent one with out the remote choke so had to order a remote kit for it. https://www.amazon.com/dp/B084FSC6ZJ...p_mob_ap_share Jets https://www.ebay.com/itm/173334772965
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-26-2020 at 09:37 AM. |
03-22-2020, 01:18 PM | #72 |
Awesome, thanks.
Man, parts for this bike are so inexpensive. I love it. I need to change my sprocket and get a little more power out of the bike to be satisfied though. I can’t even maintain speed on gentle hills with this current sprocket. Luckily, I think I’m leaving some power on the table running rich and I’m happy to buy aftermarket parts needed to get the power up a bit. And you were right... the brakes are much much improved now that the oils have burned off of them. |
03-23-2020, 09:54 AM | #73 |
Well i took the bike out for a little ride yesterday. I got about two blocks down the road and she died. I thought i might of forgotten to turn the fuel back on but not the case. I pulled off to the side of the road and she cranked right back up but would only idle and would die as soon as i would give it throttle. So I proceeded to take the carb off and open the bowl to check for trash only to discover i didn't have an Allen wrench to fit the carb screws. So i managed to limp it home at idle speed. When i got home and opened it up i found one little piece of grass that managed to find it's way into the main jet. Needless to say I have included a complete set of Allen wrenches to my tool kit. No worry, I enjoyed the rest of the day riding and self isolating myself. I will need to fine tune my idle a little more. It seems a little rich at idle.
I took the bike to work this morning. I was planning on taking all week but the Governor ordered everyone to stay home starting tonight. I should have plenty of time to work on it the rest of the week.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-23-2020 at 04:56 PM. |
03-24-2020, 12:54 PM | #74 |
I received and install new mirrors last night. These are real nice and heavy duty. The stock mirrors got to the point that one mirror i had to constantly adjust and the other vibrated and rattled. I'll post pictures late today when i get home of them installed. These are very tight and will no way move no mater how fast you're driving. At first it thought they were fixed because they were so hard to move. No plastic here. lol
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-25-2020 at 02:53 PM. |
03-24-2020, 08:04 PM | #75 |
Here are pictures of mirrors installed.
