Old 10-13-2020, 06:23 PM   #61
Nicthegreat420   Nicthegreat420 is offline
So on the original engine the valves are to spec.
Will be checking the valves on the new motor when I get home.
New motor-which has been left out in the rain for one night-
–if it isn’t a bent valve or a stuck open or closed valve, and the timing is perfect spot on, which it is—
–the ground wires are good, so no short circuits.
–there is spark
It should cough with a trickle of fuel into intake directly...?
I’ve only connected the wires needed to run the engine n idle it. No lights or anything extra
Old 10-13-2020, 10:26 PM   #62
Head and cylinder valves
Hopefully this is able to be cleaned up
And NOT replaced? Or I can replace or swap from old motor if need be ?
Valves are at .05
File Type: jpeg 4C7345F5-A7AE-4ABF-93FB-C751CD7BC637.jpeg (43.8 KB, 317 views)
File Type: jpeg 6FF067EB-B362-4C86-9226-6B27532D4405.jpeg (25.6 KB, 327 views)
Old 11-01-2020, 11:16 PM   #63
Piston and rings set and gaskets are in the mail.
Old 11-10-2020, 03:53 PM   #64
Piston came without c clips and with only 3 waffle rings... not even a wrist pin! Wtf..
Clear as day it showed over 15 parts.
Refunding ASAP and going thru amazon prime instead
2x$13.00
Old 11-22-2020, 06:21 PM   #65
Got new piston with all correct rings. One ring says R while other says RN. Where do they go. I have seen other posts n videos via YouTube they don’t explain for tao tao and I won’t risk making a mistake to blow another piston or rings.
What are the proper displacement for these rings? 120 degrees or 180?
Old 11-22-2020, 10:09 PM   #66
This right ? Gotta make sure the pic loads
File Type: jpeg 3747C039-BFE3-4B4C-9F74-321367AC9FAF.jpeg (51.6 KB, 208 views)
Old 01-25-2021, 09:01 PM   #67
If thi is correct the bike Would pop with raw fuel down the carburetor
Old 03-31-2021, 03:35 PM   #68
So I come back to the motor and go over the valves find out if they are yet again still on spec on both engines so we know the valves are not the issue at least the clearance is not the issue we don’t know if the valve exhaust is burnt and the only way to find out is to remove both valves
Again valve clearance is not the issue spent the last year of Covid dealing with everybody telling me it’s the valve clearance —it’s not
Took the head off realized it might need a rebuild I’ve gone over the wiring on the bike and removed every single wiring component stripped it from the wiring lube and completely re-wired a brand new individual wiring unit from every single component going to an individual ground from every single component so there will be no way in hell that the wiring is incorrect no fucking way in hell
There are three engine wires from the stater they are hooked up correctly
The two wires from the 12 V stater powering the light in the LED housing for the headlight is not connected Because it’s not needed to turn the engine over
From the spark plug wire all the way to the capacitor all the way to the CDI all the way to the battery every single wire is brand new I ran over every single wire with wire tracer to check for continuity so I know every single wire on my bike has not a single break crack or fracture in the line so I know in the bike there’s not a single short at all. I’ve taken a Bike to a shop to verify that all the grounds are fine they are fine are fine
Ignition switch is perfectly fine
Fuel lines are perfectly fine
Spark plug wires brand new and properly gapped
The carburetor is not even on the motor right now so I won’t need to pull the throttle or any other extras
So with all of this being said the motor is bolted into a bear frame with only the wiring needed to go from the battery to the starter to the stater to the spark plugs to complete the circuit
The bike will not turn over with starting fluid, with carb cleaner, or with pure 91
The bike has an electronic Killswitch which has been bypassed
Currently replacing the piston assembly on the motor that has 1000 miles on it— As it’s the same motor that came on the bike when I bought it
The original issue with this bike was a driving down the street come to a stoplight and the engine dies before I have a chance to pull my clutch in to put the bike in neutral
— Ever since then the original motor has not ran nor has it turned over—
Timing on both motors is perfect
it’s set perfect at the camshaft
it’s at perfect at the cam shaft sprocket
it’s at perfect at the stator
it’s at perfect at the timing marks lining up on the stater housing
When the bike is turned over it makes a chain grinding noise and the only change that I know of that’s inside the bike engine is the one that comes from the starter and the one that comes from the camshaft sprocket
To my knowledge there is a adjuster for this chain But I cannot find it
Old 03-31-2021, 03:40 PM   #69
Again I’m needing some advice to get my bike running or I’m going to sell it to the junkyard
Old 03-31-2021, 04:12 PM   #70
franque   franque is offline
Are you getting spark? When you say it's not turning over, are you saying it's not physically turning over, or it isn't firing? What does compression look like, and leakdown? How is the coil ground, and is the plug cap a resistor cap with a resistor plug?
Old 08-27-2021, 09:41 PM   #71
I’ll try n post a video
Old 08-27-2021, 10:15 PM   #72
Here I hope
Old 11-08-2021, 09:52 PM   #73
AussieMatt   AussieMatt is offline
Hey mate,
Have had a read through this thread I've been building Chinese E22 motors for over 10 years now
When you set your valve clearances was the motor at TDC when you did them ??
If it was TDC and both at 0.05 take the carb off from the manifold and cover your hand over manifold openining hit the e-start button and see what the vacuum pressure is like on it ? Weak or strong
If its weak then id try these settings go 0.03 for intake and 0.04 for exhaust while at TDC
every chinese E22 motor I've ever built in australia has been set 0.03 & 0.04 with no issues ever just make sure your valves are seated closed after setting so is best to do with head off
If all of that dosent work I'd be checking your stator output with a multi meter from the green & red/Black to see if it's within range, this is your main stator coil
Then green & blue/white to see what this is outputting and if it is acceptable range, this is your timing trigger for your spark
also what's the gap between the timing trigger point on sensor & flywheel also set at ?
Cheers
