Old 05-16-2017, 01:01 PM   #76
Originally Posted by dh View Post
2LZ didn't you find a aftermarket pipe for your Q that fit nicely?
Yes dh. I've tried two different mufflers on Q after banging the cat out of the stock muffler. There was a noticeable difference in power eliminating the stock muffler, even without the cat. Mostly top end. My only question is does your head pipe stick out from the frame at close to the same angle and length as Q does? I can't imagine that it would be much different from Q other than how it plugs in to the head to the TU 250 motor, since I believe it's the same basic frame. The first pic is of the stock muffler.
I first mounted the FMF TC2 on Q (see second pic). I've put it on my other CG (Hondoid) motors and really like it. It is also a very high quality unit.
https://www.amazon.com/FMF-Turbineco...ecore%2B2&th=1
It ended up being too loud and too shrill of a tone on the OHC Suzuki motor and I didn't like it, so I changed it to this.
You have to order a 1.25 to 1.5 muffler adapter and do a little "reformatting" on it to splice the new muffler to the FMF TC2 mid-pipe (as you can see in the third pic)
I REALLY like the sound on the OHC motor and appearance of this muffler. It seems of a decent quality and Lord knows....the price is right. It will also pass the Rangers coat hanger test. I did drill more small holes in the baffle to free it up a bit.
If your head pipe may appear to stick out remotely close to the one on Q, either of these mufflers can be fitted to the SSR XF250 successfully. If you don't start with the FMF TC2 as I did, you will need to have a mid-pipe made at a muffler shop to splice the second muffler on to your SSR XF250.
Old 05-16-2017, 05:02 PM   #77
mjs91882   mjs91882 is offline
Yeah seems high but I have seen dealers asking as high as $3600 I bought my 2013 for $2,700 including assembly sales tax and registration. Mind you this was 3 years ago and the dealer was only a few miles from SSR's HQ so shipping wasn't a factor for the dealer. I bet they have some room to negotiate.
Did you make them any offers?
No but if there asking $2999 plus taxes and registration I wonder if I could get them to $2500 cash out the door. What you think is a fair price? Your have a gas gauge? I thought someone else said the did.
Old 05-16-2017, 09:37 PM   #78
You can ask but have to be realistic. Not going to drop the price like your buying a 32,000 pickup. They will go about 100 but I don't think 500. You can try!...just saying.
Old 05-16-2017, 11:56 PM   #79
humanbeing's Avatar
Originally Posted by Derekon2s View Post
I don't know what year they added them, but mine is a '16...
What's the Ω reading
There's 2 typical chinese fuel sensor
100Ω (2-wire) http://chinariders.net/showthread.ph...858#post248858 / 500Ω (3-wire| Yamaha/GY6...)
I guess it's the 2-wire 100Ω type...
Old 05-18-2017, 10:07 AM   #80
Derekon2s   Derekon2s is offline
So i ordered the Acerbis bark busters and the Sigma jet kit off Amazon. I'll be looking for it next week sometime. I'll probably do what i can to drill out the muffler to see if that improves things also, and measure the exhaust pipe to see what size i can fit on there. How's everyone's week going so far?
2017 Yamaha FZ09
2016 Suzuki DRZ400SM
2016 SSR XF250
2003 Honda XR70
20XX SSR 125 Pit Bike
2011 Ninja ZX6R - Stolen
1996 Honda VFR750F - Sold -
2004 Suzuki GSXR750 -Totaled-
Bunch of cars and trucks. lol
Old 05-18-2017, 10:22 AM   #81
Thankfully, the week is almost done.
I'm curious to see what your exhaust measures out at. Q is 1.25" but it's only a 200.
Old 05-18-2017, 11:43 AM   #82
So, 51mm is about 2 inches. I'll see what my stock pipe is, but I'll get an adapter and weld it/clamp it if need be. Shouldn't be a big deal. Thinking something like this:
https://www.amazon.com/dp/B00L489LAC...I1MNKKJFWNE01D
Wake this 250 up! lol
2017 Yamaha FZ09
2016 SSR XF250
2003 Honda XR70
Old 05-18-2017, 02:04 PM   #83
Should be nice and quiet! LOL!
I forget what exact adapter I used and I didn't order it from Amazon so it's not on my list. I couldn't find the "perfect" one regarding inside/outside diameter on both ends but made it work. Unfortunately, my welding skills leave little to be desired, so it's all clamps, Dremel and lots of pondering.
If you don't mind some noise, the FMF TC2 is a great unit. USFS Approved also so the Rangers won't harass you.
Old 05-18-2017, 02:34 PM   #84
dh   dh is offline
I'd be interested to see what you find out. A few years back JP motorsports in Chula Vista had a exact fit slip on pipe for the Xf200. I'm thinking I might want to change my stock muffler after 2LZ's good review of the cheap Amazon one.
2013 SSR XF-250
Old 05-22-2017, 01:45 PM   #85
dh   dh is offline
Here are some photos of the Carb. I pointed out the idle screw in one of the photos. In the other two you can see the small hole drilled in the carb slide to help with the throttle response. The drill bit was included in the sigma kit with instructions. They warn that too many holes can cause on road rideability issues so I just drilled 1 hole; I kind of want to experiment and do another though.
2013 SSR XF-250
Old 05-22-2017, 05:08 PM   #86
I wonder if that little screwed on plate behind your cable is the same thing as on mine in post 34? That's what I pulled off and plugged the little port with RTV. It helped with throttle response.
Hey! If you drill one too many holes in the slide, there's always JB Weld! ;-)
Old 05-22-2017, 10:38 PM   #87
Thanks for the pics, but it's hard to tell what i'm looking at. I have the kit for the SSR and the DRZ now, so I definitely have some carb jetting in my future. lol I found the switch for the instruments and driving lights. Crazy, I've never seen that on a bike. I need to get that exhaust pipe measured, I'm pretty sure I'll be able to fabricate something for an adapter for the pipe, should it need one.
2017 Yamaha FZ09
2016 SSR XF250
2003 Honda XR70
Old 05-24-2017, 01:08 AM   #88
1cylinderwonder   1cylinderwonder is offline
Head Scratching Purchasing a "new" XF250
If seems if you purchase a "new" XF250 the new owner must recalibrate and rejet the carburetor, remove the catalytic converter, replace the stock muffler, drill breathing holes in the air box and replace the front or rear sprockets with different sprockets with different number of teeth. Seems like a lot of work, hassle and expense just to ride the bike home!
I usually ride most of my new bikes a hundred miles or further on my initial ride home from the dealer. Will I be able to keep up with traffic on the highways on my initial ride to the bike's new home? Or will I become a traffic "hazard" and impediment to the flow of traffic?
If the above is over stated, what would be the "minimum" amount of corrections needed to get the new XF250 to my home with a comfortable, smooth, enjoyable and trouble free ride?
Old 05-24-2017, 12:32 PM   #89
dh   dh is offline
1CYL I agree the bike should be broken in before doing much to it. As far as all the modifications that can be done to this bike, I wouldn't say they are necessarily a "must", but they do make the bike more enjoyable to ride and they are very cheap and easy to do. About the sprockets, I would only recommend changing the front sprocket if you plan to a do considerable riding at highway speeds and very little trail riding.
You can definitely ride this bike without any mods however. When mine was in stock form I rode it on highway 15 from Southern California to Vegas and(I'm 180 lbs plus a 50 lb duffel bag). One direction the weather was nice and the bike cruised at nearly 70 much of the way and it was very comfortable. The other direction I was riding into a 35mph headwind and it was miserable! Even then I was able to keep up with the trucks which were getting blown all over the place and only doing about 50-55. If you feel the need, it would take you about 10 minutes to rejet the carb and remove the inspection cover from the side of the air box. This only requires a couple of screwdrivers and a 10mm wrench.
Derek the black part in the photos is the carb slide/diaphram. It will make sense when you disassemble, just go slowly as there are 2 springs attached to it and they may try and fly off into outer space.
http://www.6sigmajetkit.com/cv-carb.html
2013 SSR XF-250
Old 05-24-2017, 12:50 PM   #90
dh   dh is offline
2LZ I will try and get to that screw this this weekend and see what it does.
2013 SSR XF-250
