Old 01-19-2010, 11:59 AM   #76
Good for you, Baron! It is very wise to give the local businessman an opportunity to lower his price, and get your business.
Old 01-19-2010, 12:02 PM   #77
Baron   Baron is offline
Does anyone know of a site, or know themselves how to figure out what make and model atv I have using the Vin #? That info would really help me out with this 150. Parts, manual, etc...
The VIN # is LZXSCKL2X58050026
I found a site that told me what each digit is suppose to stand for, but all I can figure out is that it's a 2005. The first digit is suppose to be the country of origin "L" what's that stand for?
Anyone know?
Old 01-19-2010, 12:20 PM   #78
waynev   waynev is offline
Wow, that was easy http://www.analogx.com/cgi-bin/cgivi...&Submit=Decode
Taken from here http://www.atv-411.com/atv-vin-decoder.html at the bottom of the page under "Universal VIN decode "
Old 01-19-2010, 12:38 PM   #79
The 'L' stands for Last Communist Empire.
Old 01-19-2010, 01:43 PM   #80
Thanks Wayne.
Unfortunatley I have a 2005 unknown, unknown from china. Hopefully most of the "Chinese ATV" parts you find on ebay will fit it.
Old 01-19-2010, 11:46 PM   #81
Don't be too concerned about the make of the ATV, Baron. It's almost identical to the 150 that my daughter rides, and several of us can guide you on the maintenance of it.
FWIW, the engine is a GY6 (apologies if you already knew that).
Old 01-20-2010, 08:24 AM   #82
Did not know that. Thanks.
Old 01-20-2010, 12:04 PM   #83
On that note then, the GY6 is a terrific engine (IMHO), and it's ideal for a new rider. The GY6 was first used on the Honda Elite scooters in the eighties. They use a dry centrifugal clutch, meaning that there's a belt under the left side engine cover, similar to a snowmobile in concept. The centrifugal clutch winds up, tightens the belt and transfers the power to the gearbox at the rear.
The gearbox is filled with gear oil, and as such must have sufficient quantity. If you look to the rear of the left side cover, you'll see a fill plug and you'll find a drain plug underneath. I use Castrol Syntec 75W90 in my daughter's quad. Syntec has a nice nozzle on top that makes filling easy. The stuff that came out of our quad was thick like molasses, and it smelled like wood preservative. 8O
Reveeen feels that the electric choke on a 150 can be problematic, so perhaps that's part of your issue. Entire replacment GY6 carbs (choke included) can be had for cheap online, and they're handy to have around. Since the quad will start for you on starter fluid, everything other than fuel delivery is likely ok.
I'm guessing that Reveeen will chime in soon.
Old 01-20-2010, 04:07 PM   #84
Reveeen   Reveeen is offline
Well ok.........
There is a vacuum port on the intake manifold, left side, just behind the stud/nut:
http://www.partsforscooters.com/Inta...9&category=360
On the right side of the carb, there is a vacuum hose that comes off the carb, and runs into a "T", one side of that "T" hooks to the intake manifold, the other side hooks to either a vacuum operated fuel pump, or a petcock, or if you have neither it would be plugged.
http://www.discountscooterparts.com/386.htm
(where the vacuum line hooks to the carb is directly opposite the electric choke seen in this pic, and assists the electric choke)
Looking again at this pic, there is a vacuum line that runs just ahead of the electric choke unit from the throttle area to the vacuum diaphragm, this is necessary.
Better carb pics here:
http://www.ioffer.com/i/KF-GY6-150cc...51?source=eisi
1st pic shows the destination of the vacuum line.
2nd shows the "T" I spoke about
3rd shows the electric choke, the "necessary" vacuum line ahead of the electric choke, and the line coming off of the "T" that you would hook to the intake manifold, the fuel inlet is clear: below the electric choke towards the rear.
4th is the throttle side again (like #1) this time with the vacuum line removed
Intake manifolds do age crack causing vacuum leaks.
Between the intake manifold, and the head, there is a plastic isolator block:
http://www.partsforscooters.com/164-...9&category=360
If the intake manifold has been over tightened (in the past), or if heat just "got it", these have been known to crack, causing a fairly major vacuum leak.
Old 01-21-2010, 07:56 AM   #85
This is probably a really stupid question but please keep in mind I've never owned an atv before. I decided to do some more work on the 150 and since all signs seem to say it's not getting fuel I decided to clean the carb again, check the lines and tank. I drained the tank and the fuel was clean, but there seems to be a bearing (or something like one) rolling around in the tank.
Is that normal? If not how do I get it out? I can't seem to get it out.
Old 01-21-2010, 10:56 AM   #86
Whatever it is, it likely doesn't belong there (and no, that's not a stupid question). Please feel free to bring your questions, no matter how basic they might seem. There could be someone else reading the thread that will benefit from the exchange of info (gotta love the internet).
My guess is that there is some welding slag rolling around in the tank. I bet that it could be removed if you work at it enough. You should be able to remove the fuel valve from the tank to make that easier.
That said, if your fuel valve has a reserve option like ours does, the slag won't do any harm.
Old 01-21-2010, 12:48 PM   #87
Try a magnet on a stick.
Old 01-23-2010, 07:34 PM   #88
STUFF IN THE TANK
What you are hearing is the ball bearing that goes inot the fuel cap.. when you tip the unit over.. it plugs off the air hole that lets the air into the tank and causees the fuel to flow to the carb.. take a look and yours will be gone unless someone else loose it or it is from another cap.. .. a magnet will probadly get it out
Old 01-28-2010, 09:58 AM   #89
ok, the magnet worked. It turned out to be two small screws. I'm glad I got them out.
I also removed the Carb again. I'm going to clean it again and post pictures of it here (hopefully tonight) so you guys can let me know if anything seems wrong.
Problem is some of the screws on the carb are stripped. I'm not sure how I'm going to get them off. Any suggestions?
Old 01-28-2010, 10:39 AM   #90
katoranger's Avatar
I would recommend utilizing a new carb. Might be time/money better spent. I believe its a gy6 style right?
Otherwise one of my favorite tools is an impact screwdriver available at most parts/hardware stores. $15-20.
It looks like a big screwdriver. All metal with a few different sized bits. You tap/hit one end with a hammer and applies a downward jolt/twist. Works great on old hondas with lots of phillips head that like to strip.
http://www.vapnapa.com/bk7759059.html
Allen
