02-17-2016, 10:55 AM | #91 |
Please explain.
02-17-2016, 12:12 PM | #92 | |
Some manufacturers, such as Zongshen and Qingqi, manufacture bikes with better quality control, and a higher standard for fit and finish. Nevertheless, most Chinese bikes represent a good value for the money spent. You are now an official China Rider.
02-17-2016, 01:07 PM | #93 | |
But I found this mod being done to several other Single Cylinder Thumper bikes (Harley, Suzuki, other Kawi's, Honda, etc.) with great success and no problems posted for years (first mod I found like this was posted way back in 06 or so ), no one ever posted doing it to a KLR so I spent the little $ to try it... had little room to do the mod but was able to do it NO problem Going to get a few more full tanks of gas run through it to get a better report on mpg... the numbers will be a little off now as I did a few other things to my bike that will effect those numbers one way or the other, but probably for the better (bigger '17t' front sprocket, new wheel bearings, thermo-bob 2, a new free flowing exhaust, different pilot jets, etc.) Bike was getting around 48 to 50 mpg when I bought it (according to the guy I bought it from, the original owner got 48 to 50 mpg, the guy I bought it from never ran a tank through himself), but it went up to 50 to 53 constantly after I did the adjustments, cleaned the fuel/carburetor/engine and did some Denso upgrades (Iridium 5730 "Racing" Spark Plug and a Denso Coil on Plug). I'm thinking I should get 53 to just shy of 60 mpg with my new wheel bearings, bigger front sprocket, T-Bob, exhaust, and a proper tune Anyways, before I get to distracted and write a novel... thanks for posting up that others have had issues with these kinds of mods. I'm used to the simplicity of the single cylinder, single spark designed bikes, and not those exotic Euro designs
02-17-2016, 04:16 PM | #94 |
02-20-2016, 05:02 PM | #95 |
OK I've run through the gamut of gearing and my general impressions are:
Stock 15T/50T-really low gearing, not practical for any type of touring, off road only, difficult to maintain speed over 50mph 17T/50T-I think this would make a great combo for off road touring, 55mph is easily achievable and cruising at 50 is no problem. 17R/45T-This combo is the best for highway cruising. Bike will top out at 65mph on the flat and sits right in the sweet spot for comfort and power at 55mph. It will easlily cruise at 60 but the engine seems a tad bit strained. Hills require a downshift but that's OK since 55 isn't a problem in 4th. The only downside is first requires a little throttle and clutch feathering to get going. This so far is the best touring setup 15T/45T-stay tuned, haven't tested yet
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
02-20-2016, 07:31 PM | #96 |
15/45 answers another question I didn't even ask, but now have an answer to!
17/45 sounds like it will be the best commuting gearing for me.
"They say that life's a carousel, spinning fast you got to ride it well..." TGB Delivery Scooter 150 TMEC 200 Enduro--carcass is sadly rotting in the backyard Last edited by culcune; 02-21-2016 at 12:12 AM. |
02-20-2016, 08:56 PM | #97 |
Great data points. I can 2nd your 15/50 and 17/50 results.
Are you planning on changing out the knobbys since you're aiming for more of a touring setup? |
02-20-2016, 09:24 PM | #98 |
I'll burn through the stock knobs before I replace. I actually kind of like them, they squirm a bit, but nothing to bad. I'm a big fan of the Shinko 244, they hook up really well in the dirt and good on the tarmac as well. I prefer 50/50 dual sport tires over 80/20 tires simply for the added confidence off road. That's despite the fact I ride mostly 80/20.
02-21-2016, 08:58 AM | #99 | |
02-22-2016, 08:44 AM | #100 | |
I plan to commute on mine a certain amount but most of the roads (even the two lane zero shoulder roads) are 55mph with people going 60-65. would be safest if I was traveling 65
02-22-2016, 11:14 AM | #101 | |
I'm still running the stock carb. I have a Mikuni with 115 main/30 pilot jets sitting in a box waiting to put on. The general consensus is richening the intake up improves drivability, so maybe 65 will be a possibility. Will probably throw the new carb on next weekend.
02-26-2016, 02:35 PM | #102 |
Hey Wolftrax where would be the best place to buy the 17T/45T sprockets for the Hawk?
Paul Mann 2015 Haosen Hawk 1989 Kawasaki EX500 1991 Suzuki DR350 |
02-27-2016, 02:18 PM | #103 | |
I saw the bottle, and the small hole poked in the bottom for air flow. I also saw what looked to be a nearly perfect spark plug. What I don't understand is what the bottle is for. Is it slowing the rate of fuel into the carb bowl? How would that affect the jet size?
02-27-2016, 03:07 PM | #104 | |
http://www.motorcycle-superstore.com...-rear-sprocket
02-27-2016, 05:23 PM | #105 | |
