Old 12-25-2014, 09:46 AM   #1171
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Dare we ask for a 21-inch front wheel from the factory?
If your assumptions are correct, I say go for it. The 17/21 is a very popular configuration for ADV bikes. The 21" up front makes a huge difference off road. I had Woody's Wheels lace up a 21" for my Super Tenere and the tracking gains off road were frankly, amazing. Instead of wallowing in mud an sand it tracked right through. Obsatacles in the path, up and over, no problem.
Though there are a number of 18"options for knobs up front it appears most of them will be rear tires. The 21" wheel has a lot more options for tire style.
My favorite setup on my Husky was this.
Up front Michellin T63(no 18" front as an option)
Metzler Enduro 3 in the rear
Would really like to try this as a rear drive. Mitas E-07
Factory option or lacing my own, one way or the other I'll get a 21" up front.
Merry Christmas everyone!
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 12-25-2014, 10:06 AM   #1172
Indeed, I also noticed a big improvement in off road handling after I converted my Zongshen ZS200GY-2 from an 18-inch front wheel to a 21-inch front wheel. One way or the other, I will make the switch once again with the Zongshen RX3.
I have heard good reports on the Mitas tires. The Metzler Enduro 3 has a very similar tread pattern to the Mitas E-07.
I also hope everyone has a very Merry Christmas.
Old 12-25-2014, 11:51 AM   #1173
Huck369   Huck369 is offline
Huck369's Avatar
a 21" does make a better off-road wheel choice, but the 18" will be the best for on-road usage.
Using a bigger front wheel "May cause contact with the "Beak" fender under the headlight, as it looks as though it will be pretty tight under full compression with the 18" tire, so switching to a 21" tire "Might" require longer forks to allow clearance.
I'm happy we're getting the 17" rear wheel, but I'll probably stick with the 18" front wheel.
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 12-25-2014, 12:04 PM   #1174
G19Tony   G19Tony is offline
G19Tony's Avatar
I hope they come out with a BMW tubeless type rim. I'd rather just plug and go.
Being vertically challenged, I'd rather not raise the bike too much. I'm happy they went with the 17 rear.
I like the KTM's, but I need a boarding ladder to get on.
Old 12-25-2014, 12:06 PM   #1175
Indeed, there is no need to switch the front wheel if you are primarily concerned with street performance.
With 5.1 inches of fork travel, I'm pretty confident a 21-inch wheel won't have any clearance issues.
Old 12-25-2014, 12:12 PM   #1176
The Nuetech Tu-Bliss system has good reviews, but the system is only sold for 18, 19, and 21-inch wheels.
http://nuetech.com/tubliss/#sthash.yvexW7Tv.dpbs
Old 12-25-2014, 12:25 PM   #1177
Originally Posted by rtking View Post
Good news is that the factory has ensured the rings are sealed against the cylinder walls. The hone will never be as sharp as when the bike is first starte, so having the engine under load on a dyno and through its full rev range means that those rings are likely well seated!
That's a good point. I certainly have heard of engine builders using an engine dyno for break-in.
Old 12-25-2014, 12:28 PM   #1178
Mathematics and tire sizing is not an accurate way to determine the actual size of a motorcycle tire.
That's a fair statement. That said, I was surprised by how far out of whack my calculations were, compared to the manufacturer's specs.
Old 12-25-2014, 12:32 PM   #1179
I think CSC made a good decision. I prefer to get the bike with the excellent cush hub, and work with the available sprockets.
There's always hope that we'll discover a sprocket that is really close to correct, perhaps with smaller bolts holes. Drill out the holes, and Robert is your Dad's brother.
Old 12-25-2014, 12:36 PM   #1180
Therefore, switching to a 21-inch front tire would improve the accuracy of the speedometer, making it almost perfectly accurate.
That's funny; I was thinking the same thing. You've obviously been a good influence on me, Spud.
Old 12-25-2014, 12:36 PM   #1181
Wolftrax's Avatar
Agree 100% here. The front fender will come in contact with the beak first. If it does a little trimming will fix that.
Mark
2014 CRF250L
Old 12-25-2014, 11:23 PM   #1182
Yes, we can search the sprocket catalogs after the bike arrives, and search for sprockets with the same measurements.
By the way, how did you know Bob was my uncle?
Old 12-31-2014, 02:56 PM   #1183
Joe got back from China and has been posting a few updates. The aluminum panniers look nice. However, the Chinese gentleman watching Joe ride the blue RX3 doesn't look very happy.
Do you want a camouflage RX3?
Old 12-31-2014, 09:52 PM   #1184
The camo doesn't look too bad. I'd consider it, but not if orange is available.
Old 12-31-2014, 10:27 PM   #1185
CSCDude   CSCDude is offline
CSCDude's Avatar
...the Chinese gentleman watching Joe ride the blue RX3 doesn't look very happy.
I told him I had never ridden a motorcycle before.
Check the CSC blog today, boys. Lots more good stuff.
From everyone at CSC, have a healthy and happy New Year!
Joe
www.ExhaustNotes.us
