Old 02-14-2007, 09:29 AM   #1
PARTS PARTS PARTS PARTS
Just add your part (and link to it if you have it) that you know will fit these bikes. I will update the thread here at the top.
Especially looking for parts that are easy to get (ie, from known parts suppliers like JC Whitney or from Honda, Yamaha, Kawasaki, or Suzuki that may be upgrades in quality)
Exploded view of parts for OHC version
http://roketa.com/product/product_su...=0&proID=25973
http://www.atvforless.com/200gy-parts-web.htm
Exploded view of the push rod version
Possible parts supply
http://www.atvwholesaleoutlet.com/html/parts.html
microfiche scans
DiamoLM200 : if someone wants to match parts by pics here is a web site you can search for the parts match
http://www.daytonafunmachines.com/fiche_select.asp
GY-5 Brakes
gomoto: Hey guys if you have a gy-5 with rear disk breaks the replacments pads are for a 07 YZF 450. They are a perfect match
UNI AIR FILTER POD $13-$15
http://www.rockymountainatv.com/prod...dFamilyId=6800
Rear sprocket bolts/pins
katoranger : http://www.chinariders.net/modules.p...ewtopic&t=4173
Walmart Seat Cover
katoranger says: I found this info for those wanting a walmart seat cover.
A712BLK
UPC is 0-4441151143-4
Stearns Comfort Ride
ATV Seat Cover
PKG-ATV07-0095
Trunk Bag
srreynolds2003 says: I found a $24 Trunk Bag This is for a bicycle rack, but it has velcro to hold it on. 13" x 5" x 7"
http://www.universalcycles.com/shopp...ls.php?id=8989
Digital Speedo from Walmart for $10
Check out the link http://www.chinariders.net/modules.p...ewtopic&t=1465
EBAY $15 Speedometer/computer.
The cool thing is in the features it shows you can set it for maintence reminders, oil change, etc. If the link is broken just go to EBAY and Search "bicycle multifunction speedometer"
Voltage LED indicator
http://www.customdynamics.com/LED_battery_gauge.htm
its a compact, waterproof, indicator, that shows battery state of charge, and of course, charge rate when running.
Turn signal bulbs
Knothead says: How about some 50 watt turn signals?? Cheaper and brighter than LED bulbs too.
http://www.jcwhitney.com/autoparts/P...002844/c-10101
Tail light and License Plate Bulbs
madmanjustice says : tail light bulb - EIKO 1157 dropped right in the Rat
license plate light - EIKO 194. Both should be easily available at any auto parts store.
Replacement KEY
RPM says: If you can find a place that has a machine and uses COLE blanks, get them to try a Chrysler "Y107" blank. It worked on the first try for me.
Battery
Can be found on ebay or other for around $30 including shipping
http://search.ebay.com/YTX7A-BS_W0QQ...2dBSQQsbrsrtZd
Replacement For:
7A-BS
GTX-7A-BS
M32X7A
44023
CTX7A-BS
YTX7A-BS
25x47x7 dust seals
Ericg64 says:
Honda OEM
91259-HA7-671
Yamaha OEM
93102-25044
LED Brake Lights
PolygonFla says: There are several companies making LED light kits for bikes.
Check out the 1157 directfit bulb here.
http://www.customdynamics.com/motorcycle_led_bulbs.htm
It should just pop right in. Or you could try the one with a pigtail.
They also sell prewired boards in verious shapes and sizes.
I replaced me taillight on the Zongshen 200 with one I found on e-bay advertized as "A custom Choper LED brake light"
Clutch spring upgrade for Roketa (and assumed other 200's)
Barnett Clutch parts number 501-56-04015
OR
http://www.jcwhitney.com/autoparts/S...&searchbtn.y=7
OR
These come 6 to a pack, so if you buy two packs, 3 guys can do this mod for about $7 ea. My Dad has these particular ones in his and they work great. They say 20% stronger than stock on the package. Part number KGS-028 on http://offroad.parts-unlimited.com/21/92/2829483
See thread http://www.chinariders.net/modules.p...ewtopic&t=1103
Clutch lever
kens97sto171 says: The number on the package is 30-23032 I think for a 1986-1888 Honda CB 450S according to this googled web site. Not in English http://www.sydfynmc.dk/honda/hondakoblingsgreb.html
But on the package is also this number.
HON #53178-MF8-000 and this one. 8642817
Scoll down till you see the numbers that match its about 1/2 way down the page. price was $4.92 http://www.leesonsmotors.com/eshoppr...EMENT_CLUT.htm
Clutch Cable
liverchip says:I found a compatible Honda aftermarket cable that works well. It is listed for use on Bike Bandit for a 2005 CR100 or a mid-70's XR75 according to the bike shop guy. Pro-Motion P/N 02-0163. The cable is about .25 inches shorter but it adjusted out for use on my TMS 200XYi
Speedometer Cable (cut to fit)
http://www.jcwhitney.com/autoparts/I...D:100000146589
Spokes
Known - Lifan and Roketa are interchangable even with rear drum or disk. Assumed to be similar for others, but you need to confirm with pics of the hub.
Headlight bulb:
BA20D type bulb with 45W
http://bulbster.com/lightbulbs/advan...?keyword=ba20d
http://www.mopedshop.com/headlight-t...2v4540w20d.htm
http://www.denniskirk.com/jsp/produc...d=41101&mmyId=
tigertamer says: This is the 35/35 halogen that I am waiting on
http://shop.wemoto.com/pictures.dyn?k=HL-770405/10
Here's a halogen, but it appears to be out of stock.
http://www.mopedshop.com/Headlight-B...ash-40whal.htm
Kawazacky says: 45/40W headlight bulb
http://www.consumabulbs.com/files/bdet.php?id=336
tail light bulb
zacstewart says: I don't know if Viva's use the same bulbs as Roketas, but the part number is 7528(P21/5W) Sylvania. It's a European bulb. I had to search for it for a while, but it works
Mirrors:
http://www.jcwhitney.com/autoparts/S...&sku=cag060449
TeamCheap says: I like these mirrors.
http://www.denniskirk.com/jsp/produc...d=11508&mmyId= I put a set on my wifes bike and the cool thing is they fold up out of the way via a double ball socket mount that has an adjustable tension.very easy install.
They have a less expensive version but were out when I had ordered hers. http://www.denniskirk.com/jsp/produc...d=11508&mmyId=
Air filter (K&N cone type):
ebay.com (39mm air filter) or (42mm air filter)
4xflyer says... I got the 42mm filter for my pz30 keihin from bikebandit.com Part# VL-61-4810.
UNI Multi-Stage Competition Offroad Air Filter
http://www.bikebandit.com/partsbandi...id~2106180.asp
Tires (Street):
Rear--- 120/90-18 http://www.jcwhitney.com/autoparts/I...D:100000209244
A 110 wide rear is recommended. 120 may require minor shimming of the exhaust and toolbox.
Front--- 3.00x21 http://www.jcwhitney.com/autoparts/I...D:100000209239
GOOD Prices for tires here with lots of selection.
www.americanmototire.com They ship fast and have tubes also.
Chain (428H - 126) "Heavy Duty"
Count the number of links of your stock chain..this has 126 links.
http://www.jcwhitney.com/autoparts/P...Ntt=428h+chain
alonzo also says: 130 link moose racing chain "428"
Part number, MSE 428 RXP CHN 130 G
Front and Rear sprocket replacement or conversion (428/520)
http://www.chinariders.net/modules.p...&p=12868#12868
Correct 15 or 17 tooth sprocket for 428 chain
http://www.jtsprockets.com/52.0.html...sel_uid=117&p=
Spark Plugs. Bold are the suggested plug.
NGK- D7EA,D8EA,DR8EA
Champion- A8, A6, RA8HC
DENSO- X16EP, X16EPR
Bosch-
ImEasy says his came with a Torch D8RTC plug in it.
It cross references to
AC - S121*L
Champion - A6YC
ND - WI6FP-U
Bosch - XR5DC
NGK Iridium - DR8EIX
Denso - IX24
Magnetic Drain Plug
Zip Ty Racing.
http://www.ziptyracing.com/products/...px?id=MTA1Mw==
Dual Star.
http://www.dual-star.com/index2/Bran...ain%20Plug.htm
Inexpensive Rear Fender Bag
http://www.4strokes.com/tech/rearfenderbag.asp
Carb jets
From Red2003: Sudco has the jets we need here for the PZ27 on the Roketa: http://www.sudco.com/keihin_mj.html#393
We need type 99101-393-xxx, so 2 jets up would be a 99101-393-112 (019-183).
Tires (Street/Trail):
sheadouglas says - Here's a pretty good sight for new tires. Good prices too.
http://www.americanmototire.com/
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
