Old 05-12-2013, 10:53 PM   #1
hallfleming   hallfleming is offline
08 XF200 parts and oil change help?
Just picked up a 08 QLINK XF200 with 77 miles. It appears the oil has never been changed. I had to pry the oil filter cap off with a small screwdriver! Once I got it off, the paper gasket that surrounds the large rubber o-ring came apart in pieces. I see the part listed as 12365-GS66-0000. I checked the DR200 schematics and don't see it. Is ordering it from jpmotorsports the best thing to do? I needed a clutch cable so I ordered that from the local Suzuki dealer from a 200SE. I hope that matches, it looked really close. I couldn't match up a throttle cable from 2 local shops. Even though it's low mileage, I wanted fresh cables. All of mine looked pretty rough from sitting so long.
Any help is appreciated!
Hall
Old 05-12-2013, 11:49 PM   #2
Congratulations on acquiring a very nice motorcycle! The QLink owners should be along shortly to provide you with the definitive answers.
Old 05-13-2013, 03:16 AM   #3
humanbeing's Avatar
Suzuki: 16510-05240 | Hi-flo: HF-131 | Emgo: 10-84200
Genuine parts from China: http://shop34613605.taobao.com/?q=QM...itemz_20130513 | http://shop36143366.taobao.com/searc...rderType=price
Old 05-13-2013, 02:10 PM   #4
I don't recally my Q's using or needing a paper gasket. If there's the appropiate O-ring you're good to go.
Old 05-13-2013, 03:22 PM   #5
Mine either. I've seen some with but I've never had a leak. Just rub some new oil on the O-ring like you do with a spin-on oil filter and you're good to go.
Don't know much about the cables, though. I do know that a speedo cable for a DR200 fits. You might be able to find a bicycle cable that matches as the ends are quite similar. I used one on a jetski when I switched to a finger throttle and it held up fine.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 05-13-2013, 03:58 PM   #6
Thw Q website may have cables, they have most parts but not at bargain prices.
Old 05-13-2013, 07:22 PM   #7
Thanks for the replies. I thought the paper gasket around the o-ring was a little odd. Maybe it was for shipping on something...
Old 05-13-2013, 08:24 PM   #8
Found that oil gasket on the parts list. It's part #18.
Old 05-14-2013, 10:44 AM   #9
humanbeing's Avatar
http://item.taobao.com/item.htm?id=17378153179 | http://item.taobao.com/item.htm?id=4247665504
Old 05-14-2013, 10:46 AM   #10
Originally Posted by humanbeing View Post
Thanks! Do you guys have this installed?
Old 03-21-2015, 09:12 PM   #11
The Thinker   The Thinker is offline
The Thinker's Avatar
Hey, I know this thread is old but I just wanted to update it with some info.
I have a 2013 XF200 with both electric start and kick start. The dimensions of the filter are 40mm tall, OD 44mm, ID 13mm. The KN-131 oil filter from ebay is a easy purchase and a perfect fit in the bike.
http://www.ebay.com/itm/K-N-Oil-Filt...0dd97b&vxp=mtr
Happy Riding
