Xpro Tahiti won’t start at all (battery good)
I haven’t been able to get this bike started since I got it 4 months ago, several minor issues I had to communicate with the company about over several months means I am not under warranty any more. Everything turned on originally but I left the lights on, ran down the battery. Had the battery recharged, it’s testing higher than before and I don’t get any power anymore. Any ideas?
Check for blown fuse or bad battery cable connections both at battery and to solenoid and grounds.
MsBurdock,
What is your location? Someone here might be able to help you. |
Tags |
bike not starting |
