04-14-2021, 09:10 PM | #1 |
2013 Tao tao 250 ATV, No spark
So heres the deal, I received a Tao Tao 250 atv that does not run from my father-in-law. After messing with it I found out that it does not have spark, among other things. I ordered a new electrical components kit from amazon. I have replaced the Coil and the CDI box. Still no spark. New spark plug, still nothing. So, I removed the side cover of the engine to get to the stator. After some research online to figure out what the reading were suppose to be on my mulitmeter. I tested the stator, and it think its bad.
It is an 8 pole stator. One wire (black with red tracer) has continuity to ground 276 ohms. Another wire (yellow) has no continuity to either wire or ground. Lastly, a (pink) wire has no continuity to either wire or ground. Concluding I believe the stator is bad. Secondly, I cannot find a new stator on amazon that looks similar or close to it. Attached are pictures of the stator and some rubbed wires I found. All info and responses are welcome. If i knew how to add pictures it would make this a better thread. Sorry :( |
04-21-2021, 10:05 PM | #2 |
Had similar problems with a TAO go cart. The CDI ignition module has a kill switch connector to a wire that was cut and a normally open momentary contact was inserted in line.
I can not find the schematic, sorry. Just disconnecting this will let you know if it is the kill switch causing the problem. |
