Old 02-25-2017, 02:17 AM   #1
zanoknight   zanoknight is offline
zanoknight's Avatar
Charging problem
I have an old hunter Xingfu china bike (very similar to hawk) When i purchased it the guy rewired the bike because he honestly had no idea what he was doing (seriously). So I rewired the bike to the best of my knowledge and I got it to run. I bought a new battery since the old one was out of commission. Charged it and put it on the bike and wooooo I thought all was well. Started making cosmetic changes and what not. About a month later my battery dies. I'm still able to ride it just not able to turn anything on. I checked the rectifier and that was good, Checked the stator and boom it was a dud. Since i was going to be in there I decided to do both jobs. I replaced the stator and the rectifier. Charged the battery and tried it again. It turned on and everything worked. This time i decided to check my voltage readings. at idle my charging system was barely hovering 10v. At high RPM I was barely touching 12.7. Could it be a wiring problem on my end or is this normal readings? Because I read it's supposed to reach in the 13v at idle and 14v under high rpm. Any info is greatly appreciated I'll post a link of my youtube if you're interested at looking at the bike.
Old 02-25-2017, 03:39 AM   #2
humanbeing's Avatar
Which type of stator & r/r in there?
Standard stator config is somthing like (fullwave)
(Honda is simialr size BUT Side-Side-Side triangle bolt pattern, others https://item.taobao.com/item.htm?id=39508069418)
r/r = 12V full-wave type http://sanxin.com.cn/Exhibit/exhview.asp?pid=42 (5-wire type had extra voltage sampling wire that often in middle http://sanxin.com.cn/Exhibit/exhview.asp?pid=53 ... )
Some older shit is for those 6v http://sanxin.com.cn/Exhibit/exhview.asp?pid=29 , AC- headlight http://sanxin.com.cn/Exhibit/exhview.asp?pid=30 ...
Ac-light system had some sort of resistor thingy that protect the filament from burning which is meaning less in ALL-DC fullwave system...
Old 02-25-2017, 03:48 AM   #3
zanoknight's Avatar
The stator is just like the picture you provided and the rectifier is a 5 pin one. Just like the Lifan motorcycle rectifier.
Old 02-25-2017, 04:20 AM   #4
humanbeing's Avatar
5-wire had at least 2 type 3-in / 2-out or 2-in/2-out & sampling which as http://www.chinariders.net/showthread.php?t=16065
Old 02-28-2017, 03:11 PM   #5
zanoknight's Avatar
Im just going to have to retest my wiring. It only charges after 8,000 rpm and that doesnt seem right.
Old 02-28-2017, 03:17 PM   #6
Ariel Red Hunter's Avatar
No, it's not right. Should have the volts go up past 2000 rpm. Should be over 12.8 by 3000.
charging, electrical, rectifier, stator, wiring
