Old 01-17-2008, 02:53 AM   #1
Guest
Posts: n/a
UH OH
wierd idle, sometimes it wants to idle at 3500 and other times purs like a kitten at 1.5. anyone had simlar experiences?
Old 01-17-2008, 08:12 AM   #2
ejcycles's Avatar
zapkin
Is your Choke on or off?... it will idle higher with the choke on. If your choke is off... this is not normal. Your throttle cable could be sticking or the cable could be routed incorrectly causing a {kink} and not letting it return correctly... The things you have mentioned are supposed to be taken care of by the selling dealer, prior to and when you pick up your vehicle.
Old 01-17-2008, 08:13 AM   #3
frostbite   frostbite is offline
Does the idle decrease when it warms up, or does it change randomly?
Frostbite
"The beatings will continue until moral improves"
Old 01-17-2008, 09:52 AM   #4
Guest
Posts: n/a
this happens with or without the choke engaged
it feels like something in the cable and I gonna check it
but it was fine when left dealer, then just sort of developed
to be honest I knew from reading forums that there would be some issues to resolve.
Old 01-17-2008, 10:33 AM   #5
katoranger's Avatar
The cable will bind easily so reach down to the carb and pull the lever down.
A good dealer would have lubed it and made sure that it wasn't binding.
Allen
Old 01-17-2008, 10:53 AM   #6
Guest
Posts: n/a
i honestly try to give other people a fine reputation to live up to.
thanks for help. will check cable.
Old 01-17-2008, 11:48 AM   #7
katoranger's Avatar
Hey, I tried to give my "dealer" a chance too. He did work had and got me a title after 6 months, but for being a custom harley repair shop they didn't do a very good job with assembly.
Anyway things get missed and if you don't ask they probably won't show you either.
I had gone to reaching to the carb and pressing the lever down to make sure the choke is off after I have used it.
Allen
Old 01-17-2008, 01:14 PM   #8
mrhyak   mrhyak is offline
Possible air leak. If the cable checks out ok, check around the carb for a possible air leak where it mounts to the engine. I've been told you can spray wd40 around the carb and if there is a leak the engine will react to the spray. I've never done this, but I've heard others talk of doing it this way.
1985 Kawasaki Tecate-3
1997 Ural Sportsman 2WD
1980 Yamaha XS1100
2005 TANK Trail 200
2009 Lifan LY110GY-3 (2)
Old 01-17-2008, 01:59 PM   #9
pumpkin   pumpkin is offline
if i remember right zapkin, your bike is less than a week old. i would take it to the dealer before i did anything.
06 american lifan 200 gy-5
Old 01-17-2008, 09:42 PM   #10
SamM   SamM is offline
Oh yeah, your dealer will fix that right up for ya! Take it back! Just don't forget to report back what happens and what they tell you.
2013 Jeep Wrangler Sahara MOAB
2005 BMW E53 X5
2011 Schutt Industries LTT-HC LQG trailer
2017 Coleman CT200U
1978 Yamaha SR500E
1979 Yamaha XS650 Special II
Old 01-17-2008, 09:43 PM   #11
Guest
Posts: n/a
yeah i am going to do that very thing tomorrow.
Old 01-17-2008, 09:50 PM   #12
The bike should have been setup correctly and tested out for you when you picked it up! Afterall, Shawn reported them as a very good American Lifan dealer, didn't he? Why is the basic setup so hard for these dealers to get right?
2005 BMW E53 X5
2017 Coleman CT200U
1978 Yamaha SR500E
Old 01-18-2008, 01:44 AM   #13
Guest
Posts: n/a
i think it will be okay.
Old 01-18-2008, 02:40 AM   #14
Guest
Posts: n/a
Old 01-18-2008, 02:47 AM   #15
Guest
Posts: n/a
