Old 11-28-2023, 01:09 PM   #2
The head is cast, if the hole is in the port and not in the cylinder its an easy enough job for a welder to fill in the hole with welded metal rod. Common job to build up metal accidentally machined off for machine shops who then take it and re-machine it the way it should have been.
If filled in properly, no voids you could even re-drill and tap holes for the bolts etc.
