04-28-2017, 06:53 AM | #31 |
Here is another tip.
When removing the engine from the frame, or replacing it, it helps a lot to have an assistant. One person can jack the engine to the proper height and help stabilize the engine on the jack. The other person can twist/tilt the engine to the proper orientation for removal/installation of the swingarm bolt. If you make all the preparations beforehand, you will only need your assistant's help for about 15 minutes.
04-28-2017, 08:16 AM | #32 |
5.5mm wifi scope/ cam ... (USB version just dozens yuan but needs android phone...) is good for the job
Review of the 8mm http://www.thp.com.hk/forums/thdeta....rum=1&pn=96948
04-28-2017, 10:49 AM | #33 | |
Now....I've never been one to believe in "Miracle in a Can", but I've been running that Lucas fuel treatment that CSC recommended for break in.....just because they recommended it for break-in. Do you think this stuff really does any good and also, have you been running it in your RX3? Here's a quote from the Lucas website. "Lucas Fuel Treatment should definitely be used in vehicles that require leaded fuel because it actually replaces the benefits of lead in gasoline...." Makes ya wonder.
04-28-2017, 01:55 PM | #34 | ||
https://www.walmart.com/ip/Lucas-Oil...ingMethod=p13n Thanks for raising this issue, 2LZ. I am going to do some research on this topic, and start a new thread regarding it. I also seem to remember that HumanBeing reported the fuel in China is terrible. If so, one would think that any possible valve face/seat defects would be causing a lot of problems for Chinese owners of the RX3.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 04-28-2017 at 02:35 PM. |
04-28-2017, 02:26 PM | #35 | |
https://lucasoil.com/products/fuel-t...fuel-treatment Walmart sells the quart bottle for $8.87. This seems to be the best value. https://www.walmart.com/ip/16777813?...&wl13=&veh=sem
04-28-2017, 02:37 PM | #36 |
I started a thread on the Lucas Upper Cylinder Lubricant at the following link.
http://www.chinariders.net/showthrea...710#post253710
04-28-2017, 08:39 PM | #37 |
Spud, you are one of (if not) the best technical/process writers on this site. Csc should definitely include this in their shop information if they dont already have such a chapter. I know you just did it for the community but is worthy of compensation if they wanted to use it.
I read it all and understood it (which is good since I am not an engine mechanic ) Trouble is, the more I learn, the scarier this stuff becomes makes me wonder about purchasing something like a newly developed 450cc zong engine
04-28-2017, 11:59 PM | #39 | |
04-29-2017, 11:10 AM | #40 |
Thanks for sharing your experience and passing on the knowledge.
Cheers, Dan K.
Dan Kearney - Black Hawk, Colorado, USA Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ." |
04-30-2017, 02:38 PM | #41 |
22,450 miles??????
Spud,
Doesn't 22,450 miles seem quite early for a top end rebuild? Was it due to inadequate maintenance, manufacturing mistake, or just bad luck? Kind of a put off for potential buyers. |
04-30-2017, 04:37 PM | #42 |
If you read the entire thread you will learn I performed the top end rebuild of the engine because of intake valve recession. This problem was not caused by inadequate maintenance; I maintain all my motorcycles very well. Regarding bad luck, I don't know how bad luck enters the equation. As I stated earlier, I must assume this problem was caused by a manufacturing defect. I hope my problem was a rare, isolated instance.
04-30-2017, 08:09 PM | #43 | |
While out riding today, I was thinking that most recreational RX3 riders, more than likely, ride 10,000 miles a year or less. By the time they get to Spud's mileage, the bike will be out of warranty... jb
04-30-2017, 09:08 PM | #44 | |
What is the difference between a "manufacturing defect" and just poor quality metallurgy? Were you able to examine the valve seat once the valve was removed? I wonder what it would cost to have a metal testing lab do an analysis? jb
