Old 08-18-2011, 11:42 AM   #181
Oengus   Oengus is offline
You can find used cone shaped muffler on eBay, they are for early model CB125’s engines and they would not have catalytic element in them, but they do not seem to have the triangle shaped bracket your does. I’ve seen them on eBay under CB125 mufflers. You need that bracket to stabilize it a clamp would not look right and may not work as well. You could have the bracket cut off and welded on a old CB125 muffler that did not have the bracket but doing that would destroy the surrounding chrome. On the CB125S the bracket is a separate part (18353-383-830ZA) it an obsolete part though. The CB125S though seems to be what that bike was modeled after, the exhaust looks exactly the same. The bracket mounts to the muffler with two bolts.
I think you could then paint the chrome you just have to sand it first to a dull finish and then prime it with high temp paint. If you contact an auto body paint supplier they could confirm that and suggest and supply the paints.
I make some assumptions and that is that everyone has access to welders and that is because I live in an industrial city, I can get small welding project done and even plating and painting done relatively cheap.
I do not think cutting open the muffler is a good idea, you would most likely destroy it and then have to replace it anyway.
Keep in mind taking out the restriction in the exhaust will also require removing the SAI device and that is pretty easy, you just cap off all the connections it had, if you do not you likely will get back firing in the muffler as it has less back pressure once relieved. Then you can increase the fuel at induction and you will get better throttle response from that. You can remove the SAI and not the muffler but that would likely eventually lead to carbon buildup on the catalyst over time as the SAI is burning excess gases and once removed it stops doing that, so those gases should be let through an nonrestrictive muffler.
You could take both to a shop and say cut this off and weld it on here, that being the triangle bracket, then take it home sand it and paint it black. But that requires removing it all from the manifold you would want it all flat and the muffler looks like it is welded to the exhaust pipe on that bike,. Cannot really tell from the images but they look like they are two pieces welded at the junction?
I think you can find a CB125 muffler for under $75.00 and then the welding could be done for about $50.00 and the paint about $20-30.00 for about $125.00-$150.00 it could resolve the issue and increase your performance…without spoiling the looks of the bike.
Or you can just buy one of the FMF or fake Yoshimuro and strap it up and call it a day.[/i]
Old 08-23-2011, 08:32 AM   #182
jaxtell   jaxtell is offline
So last week my headlight bulb went out. I had to order one from the local Yamaha place. I had thought about doing the H4 bulb conversion, but decided not to at this point and ordered two of the 6235B bulbs.
Over the weekend, I did an oil change, adjusted the chain, worked on the speedo cable and wen over the bike again. I found I was missing the nut on the side stand (which probably accounts for the tip-over incident. The bolt at the rear of the gas tank was MIA as was one of the side rack bolts under the seat. It is a good thing I kept all of my metric nuts and bolts left-over from a Suzuki Samurai I used to have.
• Speedo is about 95% working now, got the best results messing with the gear in the hub and adding a couple of washers to help keep the gears in proper mesh.
• Tach comes to life about 7000, must be a ground. I'll continue to trace those, I thought I had checked them, but will go back and check again.
• My gas gauge did also come to life and remind me it was time for the second tank of gas. Still averaging about 65MPG, as best as I can figure with Speedo not at 100%
Here are a few more pics with the tank semi-removed (sorry, they are a little blurry):
Old 08-23-2011, 10:10 AM   #183
How do you like that seat?
Old 08-23-2011, 10:22 AM   #184
The seat is comfortable! I haven't ridden more than 30 minutes at a time, but it seems like would be comfortable on a longer ride. too! The padding is fairly thick and dense.
Old 08-23-2011, 01:02 PM   #185
When it comes to chinabikes, loctite is your friend.
Old 08-23-2011, 03:25 PM   #186
ben2go   ben2go is offline
How much fuel does your tank hold?
Old 08-24-2011, 09:49 AM   #187
Almost 4 gallons according to the specs. I usually hit reserve around 200 miles (~324 kilometers last time).
Old 08-24-2011, 01:07 PM   #188
That's a good sized fuel tank! You really scored on a great little bike, Jax!
Old 08-24-2011, 03:52 PM   #189
I have a 5.5 gallon tank on my 89 GS500.That's about what I get when I have to hit reserve.So that's good range in my mind.I get high 40mpg when I just cruise and stay outta the throttle.
Old 08-26-2011, 02:09 PM   #190
I used to have a GS500e, it was a very neat bike! And fast for a 2 banger 500, too.
Old 08-27-2011, 10:22 PM   #191
Made another attempt at the Speedo, which still fluctuates above 70KPH.
This time I focused on the hub drive, removed the wheel and the hub. The fingers were bent, which probably wrecked the gears inside. This explains why it has never worked correctly. The first picture is of the hib before. and the second is of the fingers after I straightened them.
After it was over, not much change. Still not working correctly!
Bent;
Straightened;
Old 08-28-2011, 12:47 AM   #192
My goodness; that's a fubar speedometer drive! 8O Oh, well; you still got a great deal on that bike, Jax.
Old 08-29-2011, 12:07 AM   #193
I think that HUB was forced when assembled….I also think that your tachometer is mechanical and not electric.
Its a mechanical connection here:
The cable look like this:
It spins at that location, what is inside the engine I am not sure? The fact it is only spinning at high rpms concerns me, hopefully its no destroying another part?
Old 08-29-2011, 12:10 AM   #194
That looks like a clutch cable and the location that it connects to the lever on the engine case.
Old 08-30-2011, 01:47 PM   #195
The Tach is electrical, I checked the connections. But yesterday this happened (look at the tach needle):
[img]
https://lh3.googleusercontent.com/-K.../s640/Tach.jpg
[/img]
