Old 06-04-2012, 11:43 PM   #1
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
check your bearings more often than me ;) (pics)
had the sprocket side rear wheel bearing blow up on me this last weekend, I had to push the bike out but luckily not too far. keep those things greased!
the two balls at the bottom are actually one that had split in half.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 06-05-2012, 12:43 AM   #2
Wow! I've never seen a ball bearing split before. 8O
With any of the bikes that I've been serious about, I've installed sealed bearings. I've never had one come apart on me.
Old 06-05-2012, 01:17 AM   #3
it was a sealed bearing (lower left pieces) , didn't seem to help it all that much though the hub also has and attempt at a seal too but the silt i ride in gets through them pretty easily it seems, this is my third set I've worn out in the back, but the first time one grenaded like that. 8O
Old 06-05-2012, 01:23 AM   #4
Thanks for posting the prudent warning, WA. 8O Every time I remove the rear wheel I inspect all parts of it thoroughly, especially the wheel bearings.
Old 06-05-2012, 12:34 PM   #5
Good reminder.
I should check the YZ again.
It has THREE rear wheel bearings, two on the sprocket side. Still not sure how that works...
Old 06-05-2012, 11:05 PM   #6
having two on the sprocket side helps it spread the load of the engine pulling on it without gernading :wink:
Old 06-05-2012, 11:19 PM   #7
TheGammaGhost   TheGammaGhost is offline
I'm going to buy some lithium grease asap, thanks!
2021 Boom Vader Gen 2 BD125-10 Current
2011 DRZ400S Current
2006 LIFANIZED ROKETA DB-06 200cc Sold
2008 Ninja 250R Sold
1984 Honda aero 125 Sold
1980 Honda CM400T Sold
Old 06-05-2012, 11:30 PM   #8
That's correct. My XT225 rear wheel also has three bearings, with two on the sprocket side of the wheel.
