Old 06-10-2012, 11:48 PM   #1
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
rear brake cable conversion
my rear brake pull rod adjusting threads have stripped out so I installed a cable to actuate the rear brake instead. this also keeps the rear brake consistent regardless of what part of the stroke the rear tire is in and prevents the rear brake from dragging in the air when the suspension is all the way relaxed and also when bottomed out. now the changes in geometry are taken care of by the cable housing.
I used a $10 clutch cable off of eBay for some Chinese bike that had the mounting options i wanted and cut the housing and cable to the lengths I needed
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 06-11-2012, 01:19 AM   #2
That's ingenious! Nice work, WA! If you have time, please post closeup photographs of the two mounting points for the cable.
Old 06-11-2012, 01:53 AM   #3
slotted bolt holding the cable against the brake pulling arm.
partially drilled and slotted housing mount
lower housing mount was made from my old motors clutch cable carrier welded the the brake ramrod. this also allows for easy tension adjustability.
i used the old mounting style that the rod used but modified the mounting piece to hold the end of the cable and pinched in the carriers for the mounting piece so it cant fall out if there is a cable going through it.
there is also a protective sheath over the entire cable to minimize damage from rubbing the swing arm
Old 06-11-2012, 02:25 AM   #4
Thanks for posting the additional photos, WA. You did an excellent job!
Old 06-11-2012, 10:28 AM   #5
Nice work! I hadn't considered that a poorly designed drum brake could tension the shoes during articulation.
Old 06-11-2012, 11:44 AM   #6
Excellent work and it answers a question for me too. :idea:
My XR250 used a cable actuated rear drum brake and I never knew why, now I see the advantages. It also is a little nice to not have to adjust the push (pull?) rod when adjusting the chain.
Nice reinforcement work on the swingarm.
That bike is certainly not a pampered garage queen. :wink:
