05-27-2013, 06:19 PM | #1 |
ZS-125 Engine replacement?
Hi guys,
Im thinking about swapping my standard 125cc Honda CG clone engine from my Lexmoto/Zongshen Arizona for something like a 200/250. Are there any engines out there that will slot right in without any major mods/swearing? What about the CG250 lump? Will that pop straight in? Thanks in advance chaps. Culley.. |
05-27-2013, 07:43 PM | #2 |
I sort of doubt it. Even if it was possible I think if would be a lot less time and effort to just get a 250cc or so bike.
05-27-2013, 10:15 PM | #3 |
I would think if your 125 is a vertical engine, and not a hroizontal like the 110 derived engines a 200 would bolt right up...
05-28-2013, 01:43 AM | #4 |
I believe that a CG200 or CG230 (there really is not 250) would fall into place. The reason is that both of those motors are derived from the CG125, and I would guess that they're all identical externally.
05-28-2013, 01:45 AM | #5 |
If you have specific CG200 measurements that you need, just let me know.
05-28-2013, 05:40 AM | #6 | |
Thanks for your replies chaps.
Do you have a link/full spec sheet for the CG200? Cheers.. |
05-28-2013, 07:09 AM | #7 |
yeah i agree with weldangrind. but the space for the bigger carbie needs to be measured between the head and the monoshock (?), tank and seat. i don t know what the zong 125 frame is like.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
05-28-2013, 08:38 AM | #8 | |
http://www.lexmoto.co.uk/ZS125-30/600/2.jpg |
05-28-2013, 09:18 AM | #9 |
i've got a cg230 tell me what measurements you need and ill go get a tape measure out just let me know if you need metric or imperial measurements
05-28-2013, 10:06 AM | #10 |
dual shockies no worries. the carbie if you think 26mm mikuni, is higher too, where does your throttle cable run?
05-28-2013, 10:14 AM | #11 | |
05-28-2013, 10:28 AM | #12 |
Whats the difference between a counter-balanced engine and a non counterbalanced?
Sorry im pretty new to the world of bikes. |
05-28-2013, 10:58 PM | #13 |
A counter-balanced engine has a tiny shaft at the front of the engine that resembles a crankshaft, and it provides (somewhat) opposing forces to the crankshaft. It's the finned portion at the front of your engine.
