Old 10-10-2013, 01:16 PM   #31
Your ZS250GS has essentially the same engine as my ZS200GY-2. Zongshen increased engine displacement in your bike by increasing the cylinder bore. Therefore, the bottom end of your engine is identical to mine. I have ridden my ZS200GY-2 for 60,000 miles, so I know this Zongshen engine is reliable.
I recommend the Mikuni main jets for you bike. You can find the information by searching the "Zong Sticky" located at the top of the Dual Sport Forum. I'm sure you will get better engine performance after your carburetor is properly jetted for your altitude, exhaust system, et cetera.
However, I'm going to discourage you from riding your ZS250GS on the freeways of Arizona. I don't think any, 250cc Chinese motorcycle has enough reserve power to travel safely on limited access highways.
Old 10-10-2013, 04:27 PM   #32
bsskibum   bsskibum is offline
bsskibum's Avatar
Heheh how very wise about freeways. Mainly I want to ride out of valley to jerome and sedona.. via secondary freeways and to be able to ride around 60 steady and not worry bout over heating her.. I have seen over on the tw200 forum a member created a cooler kit I was thinking about.. what are your thoughts on that?
Old 10-10-2013, 04:37 PM   #33
60,000 miles Brother Spud!!!!!!
OMG how fast they grow up!
Seems like just yesterday I was riding it when it hit 40,000 miles!
Congratulations!
Old 10-10-2013, 06:08 PM   #34
I'm not trying to be negative, but I think your secondary freeways are still more dangerous than the freeways in many parts of the United States, including my part of Idaho. Perhaps FastDoc will relate his experience riding a Zong on the freeways of Eastern Washington.
I think the TW200 oil cooler might be a nice modification for your street bike. However, if you change you engine oil every 1,000 miles, and keep your valve clearances adjusted, you certainly don't need the oil cooler. I think the oil cooler definitely creates vulnerabilities for an off road motorcycle.
Old 10-10-2013, 06:19 PM   #35
Congratulations!
It was in August, 2011, when you witnessed the Zong reach the 40,000 milestone.
Once a Zongite, always a Zongite!
Old 10-10-2013, 07:03 PM   #36
Thanks for the pics and the great memories. Thank you for letting me ride the Zong.
Old 10-10-2013, 07:05 PM   #37
"I'm not trying to be negative, but I think your secondary freeways are still more dangerous than the freeways in many parts of the United States, including my part of Idaho. Perhaps FastDoc will relate his experience riding a Zong on the freeways of Eastern Washington."
I was run over from behind and could have been killed by a teenage girl texting on her cellphone. I was going about 65 when she hit me, going MUCH faster.
Don't ride a little CB on the highway. The risk/benefit ratio is bad.
Old 10-11-2013, 10:32 AM   #38
weldandgrind..
when I first saw the ad on craigslist, the seller says this isnt a crotch rocket ..it isnt fast.. its china crap. but it will get you around town and can pass people...
When I took it home from his house,( where he had a brand new ninja 250 sitting next to her) she didnt even go over 55 with it cutting out around 5000rpm...
I thought for about a week that was all she had.. then I found this magical site and starting googling the bike and what the motor should be producing and discovered problems along the way.
after alot of tweaking I am almost to her potential, and after owning alot bigger bikes over the years ( suzuki gs500/honda cb750/honda gl500/suzuki 1100e) and a few scooters (eaton beamer 50/eaton matrix 50) this bike rates right up there for enjoyment, for riding around town. The 65mpg isnt too shabby either. It was all the seller said it was.. But even more...
problems encountered (found and repaired)
stretched chain
valve job
clogged oil filter
headlight bulb mount broken (bulb fell and was saved before it melted anything)
carb float gummed up and sticky
excessive spark plug gap (+/- .14)
broken front blinker mount(fairing cracked)
exhaust crushable washer not seated fully
stay tuned a few more upgrades are on the checklist..
air filter pods..
needle jet upgrade
front and rear sprocket ratio change (I want it to go around 80 so I can get on the freeways)
You've made excellent progress. Please remind me; was it the valves that were the major issue? Was it simply a matter of cleaning and lapping them?
Old 10-11-2013, 10:38 AM   #39
bsskibum's Avatar
No lapping.. juat a valve to rocker tappet clearance adjustment. I think since it was still in break in(1000miles) it was just time to adjust
Old 10-11-2013, 10:40 AM   #40
bsskibum's Avatar
Maybe I used wrong terminology..
Example.. highway 89 in arizona is what I wanna be able to hit.
Old 10-11-2013, 01:09 PM   #41
You inspired me to try the Plastidip. I looked at some info online and it seems interesting.
I recently scored a new plastic kit for my YZ at a great price and installed it last night. The plastic I replaced was in good shape and only about 2 years old, if that but was showing wear. I can't resist a deal, less than $80 for a brand new complete set :-)
So I'm going to try to Plastidip my old set in Yamaha(like) blue and keep it as a spare.
If I like it I may Plastidip clearcoat my new set to protect it on the trail.
I'll post pics in a seperate thread if there is interest in seeing the work.
Old 10-11-2013, 01:28 PM   #42
Where did you get the deal on the plastic kit? I am looking for such a deal for my CRF250X.
Old 10-11-2013, 02:02 PM   #43
bsskibum's Avatar
Ya a thread would be great.. I will alao do a step by step thread.. heading to lowes tonight after class to get the colors and the matte clear coat...
Old 10-11-2013, 02:07 PM   #44
What is the speed limit on Arizona Highway 89?
Old 10-11-2013, 02:08 PM   #45
Please do start a new thread on this topic!
