#1741 |
Katflap, those are terrific pics. I'm quite impressed by the build quality of this bike, and I covet it.
#1742 | |
#1743 |
Katflap,
If you have time, and are so inclined, I would love to know the dimensions of the counter shaft (C/S) sprocket. ![]() You can loosen the locking tab by tapping it lightly with a hammer and chisel/screwdriver. Just widen the tab enough to loosen the bolt. ![]() ![]() If you have access to a caliper, or a machinist, you can obtain the following dimension of the C/S sprocket. ![]() ![]() After you measure the C/S sprocket, you can re-install it on the counter shaft, and tighten the bolt. Then you can crimp the locking tab back in place with a pair of pliers. The locking washer has two tabs, and I'm sure you can re-use both of them several times. ![]() Now is an excellent time for me to do some research, and determine a compatible C/S sprocket for the RX3. Once we find an identical C/S sprocket from a major manufacturer, we will have a larger variety of vendors and sprocket sizes from which to choose. ![]() ![]()
#1744 |
Banned
Wow, Thanks everyone , & please, keep that good info coming:)!
Kat, and Spud, Thanks for answering my Q re seat removal and associated Q's.
Weld, I understand completely ![]() ![]() 40-50 whp in a 300-350 lbs bike seems PERFECT for adv riding ![]() AT approx $2000.00, (it hopefully stays about at wr250 r kit pricing) best hp per $ spent, BY FAR!. (besides opening it up at airbox and exhaust,. etc.) There isn't any guaranteed pricing on a kit, yet, however. If he does a group buy, and or decides to sell kits, then I'd bet its the same $ or VERY close, to the wr250 kit he's sold since 2008 or 2009! He sold quite a few, though, and if it wasn't reliable, or was grenading engines, we'd be hearing about it, LOUD and clear! for sure! After I put 20,000 + miles on mine with the turbo installed, (hopefully also, without any major issues) it definitely will silence SOME of the naysayers. (some just like to hear or see themselves, apparently. Logic and or truth isn't a part of the equation, for them, unfortunately ![]() Highest miles on a wr250 turbo is or rather was 48,000+ without a rebuild or any major issues. I'd be happy with that mileage on a rebuild, I think, with or wthout being turboed ![]() |
#1745 |
Banned
OOPS, again
$250.00? unless Nikasil needs a replate. I have yet to dissassemble a nikasil engine, so not sure about its lifespan and or expected lifetime.
I've heard of 250,000 miles and still spec'iing good, but haven't SEEN any thing myself. One thing, though, thats good ![]() ![]() ![]() ![]() AGain, the piston squirters should eleminate wear or at least minimize it, and the Yamaha, DRZ' etc all last at least 90,000+ before needing a rebuild. From reports on ADV forum, the bikes usually are running perfectly, just from curiosity and to prepare for a long cross country, or epic length ride, insuring reliability when on the trip. Gaskets and ring packs are the only items being replaced. ![]() One KTM rebuild needed crank bearings replaced at 120,000+ miles I read. Nikasil was good, piston reused, just rings, gaskets, and seal sand seats in head were done, as well as setting valve gap to new specs with proper shims. (we avoid shimming, of course, ![]() ![]() ![]() |
#1746 |
zongshen rx3 accessories
i was looking at the accessories listed on the csc blog,,,wow maybe im missing something ,,,,but $350 for a set of cree l.e.d, driving lights,,, hope thats not a sign of how the parts we need are going to be priced . ,,,i think these would work just fine,,i already placed an order ,http://www.ebay.com/itm/151434883274
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
#1747 |
Katflap,
The tray which holds the air filter element is held by four bolts. You must remove the bolts and slide the tray out under the frame in front of the regulator/rectifier. ![]() The air filter tray is blocked by the the two side covers on the left side of the bike. The front, black side cover, and the rear, colored side cover must be removed before you can remove the foam air filter. Your Honley has the older version of the colored side cover, which is pierced by a support for the luggage rack. Therefore, you must remove the bolt for that support before you can remove the entire, colored side cover. Zongshen modified the colored side cover, and split it into two pieces. You can purchase this modified side cover at Taobao. http://item.taobao.com/item.htm?spm=...ucket=6#detail ![]() When the modified side cover is installed, you don't need to remove the bolt for the luggage rack, because you don't need to remove the entire, colored side cover. You merely remove the front portion of the side cover to gain access to the air filter tray. ![]() The RX3 bikes imported by CSC to North America are being delivered with the improved, split side cover. ![]() ![]()
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 02-07-2015 at 08:07 PM. |
#1748 |
I like the way Zongshen continues to refine this motorcycle.
![]() ![]() ![]() ![]() The bikes imported by CSC have the old headlight, but one can always replace it later, if he pleases. ![]()
#1749 |
The dirt bikes with the NC250 engine come with a folding shift lever.
![]() ![]() Here is the folding shift lever. ![]() http://item.taobao.com/item.htm?spm=...ucket=6#detail ![]()
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 02-07-2015 at 08:08 PM. |
#1750 |
I think that's a Decepticon.
#1751 | |
Excellent upgrade. I install one on every off-road bike I buy.
#1752 |
Banned
Folding shifter
How to order from Taobao? I don't understand it nor know how to convert to US currency to know pricing. (I KNOW there is ann easy answer here, but I missed it somehow... I wish someone would do a Group Buy on these, I'd be in for sure! Pay in advance, even. If they have a rear brake lever, I'm in on that as well
#1753 | |
It also says 'adjustable front shock' ... is that an upgraded design too? I understood the CSC Cyclone forks were not adjustable, but could be wrong. |
#1754 | |
![]() ![]() Indeed, it does appear Zongshen has added rebound damping adjustment to the fork caps. ![]() ![]() ![]() The headlight has also been modified to add at least one more LED. Here is a photograph of the stock headlight. ![]() I'm not exactly sure of the construction of this headlight. Apparently it has an LED strip on each side of the headlight. I believe the blue oval at the bottom is basically cosmetic, and serves as a running light. I don't know if the blue oval contains an LED, or an incandescent bulb. The main light is an HS1 incandescent bulb. The new headlight is described as an LED upgraded version of the headlight. The new headlight contains at least one more LED bulb in the main body of the headlight. ![]() ![]() ![]() Both headlights are sold on Taobao at the following link. The stock headlight costs 138 Chinese Yuan. The new, modified headlight costs 438 Chinese Yuan. http://item.taobao.com/item.htm?spm=...ucket=6#detail I haven't yet seen the improved forks for sale, but I am sure they will soon appear on Taobao. ![]()
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 09-19-2015 at 12:49 AM. |
#1755 | |
