Old 01-21-2017, 04:41 PM   #1
tomalak007   tomalak007 is offline
Side Panel mount wrong?
Maybe I'm dumb but it seems my side panel mount is welded in the wrong spot or I'm missing a part?
Old 01-21-2017, 04:52 PM   #2
I had to rebend my bracket to make it line up.
2020 Kawasaki Vulcan S
Old 01-21-2017, 05:18 PM   #3
But not re-weld it?
Old 01-21-2017, 06:58 PM   #4
Originally Posted by tomalak007 View Post
But not re-weld it?
No. It's a hard to tell from the picture. how off is it??
Old 01-21-2017, 08:54 PM   #5
I bent it a little and it's still about an inch off! If you look at the picture you can the mounting bracket on the left and how far it's off. If possible can you take a picture of yours?
Old 01-21-2017, 09:22 PM   #6
Here you go. Not sure why the picture is turn sideways.
Old 01-21-2017, 09:33 PM   #7
looks like you had to bend and straighten yours quite a bit yes?
Old 01-21-2017, 09:53 PM   #8
Yes, I straightened the first bend by the frame then bent the nut end a little more till it lined up.
Old 01-22-2017, 08:00 PM   #9
I've had tabs like that which have been ridiculously far off. A MIG welder is your friend.
Old 01-22-2017, 08:24 PM   #10
I ended up bending the crap out of the mounts and got the panel to mount. I just wonder if they are all like that or they just welded mine in the wrong spot
Old 01-23-2017, 12:40 PM   #11
I would suggest, if, if, if, it is indeed incorrectly placed it will show up again.
Never mistakes on these fine steeds
