Old 11-19-2017, 06:20 PM   #61
Originally Posted by ben2go View Post
There appears to be plenty of meat in there to hog out on both sides for better flow. Do you think there would be any gains in cutting back the guides so more heat is put into the head and increase flow?
I have never been a fan of cutting back valve guides. I just shave as much as I can around them. The guides themselves don't actually sit in a bad place. Its just the amount of casting around them that eats up so much port space. You could probably cut them back a bit though.
As far as heat into the head goes. A better flowing port, in my experience, makes for a cooler head, port, and valve since the burning exhaust gas exits faster.
Old 11-20-2017, 10:48 AM   #62
Defiantly room for improvement. I'm ready to do mine but will be on hold until I get these skid plates and center stands going.
2020 Kawasaki Vulcan S
Old 11-20-2017, 04:53 PM   #63
At the rate I am going with all of the other things going on in my life, it will be a bit before I really get around to this as well.
My Goldwing is partly to blame for that. I decided to keep it, so it is getting quite the makeover. I am going to take itdown to the frame, clean it up, paint it, fix and upgrade parts of the motor, rewire it with a motogadget m-unit, and I got my hands on a complete efi setup from a gl1200 to put on it with a microsquirt. I also have a new swing arm to lightly modify for a 150 rear tire, a rear diff, and 2 late model 1000 drive shafts in thr mail with all of that. An extra set of wheels to lace new rims on as well, all with nearly new brake rotors on them.
Yeah... I kind of went insane... lol
Old 11-21-2017, 08:26 AM   #64
You do have your hands full. I have way to many irons in the fire as well. Speaking of fires. Saturday I came close to burning my shed down which is about 5 feet from my camper. I was welding right outside my shed door. A spark from welding had flew inside the shed and set a towel on fire which then set a garbage can on fire which worked its way to the work bench and set some plastic bags on fire. To top it off it was windy and was making it spread faster. The fire extinguisher was inside the shed I was able to get around the flames and grab the fire extinguisher and put it out. Came close to losing the shed, camper and everything in the shed including the wife's 4 wheeler. That would of put a damper on the planned camping and trail riding trip we are going on. A new larger shed would of been nice though.
Old 11-21-2017, 01:25 PM   #65
ben2go   ben2go is offline
I've got to quit reading your threads. In my mind, I have stripped and complete redone my '00 V Star Classic a few dozen times. I almost dropped nearly $1000 on wheels, Batwing fairing, and other misc. stuff including some engine warm up parts with head work and high comp pistons.
Old 11-21-2017, 02:25 PM   #66
Holy cow! I am glad you didn't end up burning down everything. Not to make light of the situation, but while I was reading that chain of events it was being played in my minds eye something similar to a Laurel and Hardy skit lol.
Dooooo it.
Many of my friends actually comment that I seem to be something akin to a Muse for getting them working on their projects. Truth is, I don't really drink or go to bars, and my body is too messed up to do some sort of sport for a hobby. I'm not really into watching sports on TV. So this is my equivalent of a few beers after work, or fantasy football, etc. I blow all of my extra time and money on my bikes and my truck.
Old 11-21-2017, 03:33 PM   #67
LOL I had a good laugh after. I was like, I hope nobody saw that I'll make damn sure I have the fire extinguisher out side the shed next time I'm welding. Gave me a chance to see if the extinguisher worked. lol
Old 11-21-2017, 06:19 PM   #68
Dooooo it.
I can relate. I'm not a sports guy and health issues keep me from participating in strenuous activities. It's actually a project I have toyed with and will do some of it, but probably not hotrod the engine. Exhaust and intake mods at most.
Old 11-21-2017, 06:20 PM   #69
Glad to hear it wasn't worse.
Old 11-21-2017, 08:32 PM   #70
That sounds exactly like my Goldwing. The efi isnt for performance at all. None of the planned engine work is either. Higher output stator, new metal impeller water pump, new timing belts with updated tensioners. It is all in a quest to modernize the bike without really changing its personality.
Old 12-10-2017, 03:47 AM   #71
I managed to get home for a day, but since I don't have my burrs in yet I decided to start with the comvbstion chamber.
I sanded down the machinist ridge around the valve seats, and blended them into the chamber. I also tried to smooth out the other ridges in the chamber. I definitely increased the chamber size a tiny bit, but I will mill the head a little more to compensate. The amount of area opened up around the valve at lower lift and the smoother airflow path should make a good difference.
Thise was all by hand, no power tools. Finished with 1500 grit for now. I will wait on the final polish until i get the reat of the head done.
The pictures don't do this justice. A lot more was removed than it seems. The first picture shows the ridge around the exhaust valve still in place for comparison.
Old 12-10-2017, 07:22 AM   #72
Nice. Ridges create hot spots that can lead to detonation.
Old 12-10-2017, 02:22 PM   #73
That's one reason why they are gone, but another reason was to unshroud the valves a bit.
Old 12-11-2017, 09:26 AM   #74
Nice work. After reading Silva's post I want to get mine done soon. I was temped to pull the head off Sunday but the weather was to nice so I went ride instead.
Old 12-11-2017, 02:17 PM   #75
Yeah. It's somewhat time consuming. I am going to be a bit more aggressive than Silva was with his port work. His was just a blend and clean up. Call his a stage 1. Mine is looking more like a stage 2.
