Old 04-08-2018, 05:00 PM   #1
Mowgli   Mowgli is offline
HELLCAT won’t start in cold
I just received my hellcat a few weeks ago and have put about 25 miles on it. Little thing is great when it’s warm outside but lately we have had 50 deg mornings and I can’t get it to start at all with the cold weather. I tried for awhile one morning till I noticed the starter getting hot (used in short burst). I let it cools back down and put a space heater next to it and 5 mins later it turns on. I’m guessing this is a carburetor issue? How do I get it so I’m able to start in the cool weather and also when we hit 95+ deg days
Old 04-08-2018, 10:23 PM   #2
I only had experience with vertical thumpers, but when I was commuting on my TMEC 200 enduro in the winter in Yuma where it could be in the 30s Faranheit in the early mornings, I had to use the choke to start it and warm it up. Not sure how the setup is with the Grom-cloned 125cc horizontal thumpers' carbs, but that is my first (un)educated guess. I only throw it out there for the reasons to start with the simple stuff first. But you might not have an easily accessible choke, or a choke that you can access like the enduros' carbs.
Old 04-08-2018, 10:35 PM   #3
The choke is mounted on the bars. This is trying to start it with the carb choke fully closed(pulled backwards)
Old 04-08-2018, 11:23 PM   #4
Hellkitty   Hellkitty is offline
Hellkitty's Avatar
The choke on mine is closed (choke on) when it is pulled toward me (sitting on the bike)
Old 04-09-2018, 01:12 AM   #5
Mines the same as that. Are you running the stock carb on yours? Or have these cold weather starting issues
Old 04-09-2018, 06:52 AM   #6
Bruce's   Bruce's is offline
Have you removed the air filter and visually checked the choke plate is closing ?
Old 04-09-2018, 12:10 PM   #7
I have. Even after pulling the lever all the way closed I’ve also reached to the carb and pushed it the rest of the way closed since it seems like the cable didn’t have enough tension
Old 04-09-2018, 04:08 PM   #8
wlfpck   wlfpck is offline
Pull the choke and give it like an 1/8th throttle when you try and start it.
I have no idea if this is just due to the stock carb/intake but I've never had an issue with mine, but I'm on the Mikuni VM22.
Never had the stock carb/intake on long enough to test it in the cold.
Old 04-09-2018, 05:42 PM   #9
I tried that also. No luck. Where did you get your carb from?
Old 04-10-2018, 09:07 AM   #10
https://www.cajunmaddogs.com/product...or-upgrade-kit
Old 04-10-2018, 10:11 PM   #11
I adjusted the valves and that seems to have fixed the issue
Old 04-11-2018, 01:04 AM   #12
Considering these engines are pretty much scooter engines, that makes sense. Scooters need to be adjusted every 600 miles. For comparison--my TMEC 200 enduro I put about 12000 miles on commuting in the desert southwest for 2 years, including 6 months of near/at 100 F afternoons, I NEVER adjusted the valves. (TMEC uses a Zongshen-OEM 196 cc engine in their enduro)
Old 04-11-2018, 11:56 AM   #13
Well I though I had fixed it. 65 deg out side. Sat in the garage overnight and still same issue. Garage was probably 55deg
Old 04-11-2018, 04:49 PM   #14
Chinabike   Chinabike is offline
You upgraded your carb? what size and jet sizes? Have you played with them?
Old 04-11-2018, 07:13 PM   #15
Not yet. I ordered one and it will be here Friday. I just adjusted the valves so far but that didn’t help the cold start issue I’m having
