05-19-2018, 02:18 PM | #31 |
I almost bought the Coffman for my CB500X. I like stealth to much. Plus we have a lot of areas here with 24/7/365 noise ordinance.
05-19-2018, 03:08 PM | #32 | |
I do know that with both the internal baffle and end baffle removed, they are ridiculous. With both installed, they actually aren't too bad, but they are about as loud as I would want to go on the street.
05-28-2018, 12:09 PM | #33 |
Roadworthy now and cleaned up. The new pads were fun to install. First time dealing with 6 piston linked brakes that are 4 piston front, and 2 pistons with their own little tiny pads linked to the rear pedal. Took about an hour. Not really sure I want to park it at work though... I guess I don't have much of a choice, let's hope the thieves in the area aren't in the mood for a big loud bike.
05-28-2018, 02:12 PM | #34 |
She sure is purdy! That looks like a bike thief's dream. You might want to hire an armed guard.
05-28-2018, 02:21 PM | #35 |
That's my fear with taking it to work.
05-28-2018, 02:27 PM | #36 |
From what I read in your other thread I wouldn't feel safe bringing I to work either.
05-28-2018, 04:12 PM | #37 | |
I guess we will find out.
05-28-2018, 04:15 PM | #38 | |
05-28-2018, 04:17 PM | #39 |
[QUOTE=Megadan;281467] I need to figure out how to adjust the sensitivity on it, but a quick test shows it to work if anybody moves the bike a little bit.
QUOTE] There is a way to adjust it. I'd have to look through the instruction. Edit: Found it. Push the bell button in the red control until beeps, then released, wait until hear 4 different beeps combinations. Choice one, pushing the bell button once after you heard the desired set up. 4 means max. sensitivity, 1 means min. sensitivity.
05-28-2018, 04:53 PM | #40 |
Set it to max. Now its perfect.
The security isn't armed unfortunately, but being in the lot should be enough to keep the opportunists away.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 05-29-2018 at 01:25 PM. |
12-16-2018, 08:13 AM | #41 |
Just because I can. Tank grips made a world of difference on this bike, especially after the suspension upgrades. Other than that, I haven't done a whole lot to her. I did manage to get it on a dyno for a quick power pull and it made 167.6hp@10,000rpm corrected, which is about 20 to 22hp more than an average 1200F makes at the wheel stock. I honestly have no complaints at this point, and just a few small changes I want to make.
This was right after a full detail a couple of months ago.
12-16-2018, 09:12 AM | #42 |
Very impressive what mods have you done besides the exhaust.
12-16-2018, 04:32 PM | #43 |
High flow filter and airbox bottle delte and the ecu flash tune.
12-16-2018, 07:30 PM | #44 |
I guess I should note thathat the heavy increase in power was not just peak power. The factory Honda tuning was super lean below 4k, and the ignition timing was severely retarded across the board to make it capable of running 87 octane. It currently has a 91 octane tune optimized for exhaust and intake. That is why there was a 20+ hp increase. That makes this bike close to 200hp at the crankshaft, and over 100ft/lbs of torque from 3800 to 10,000 rpm. It is a freaking missile, and I rarely ever find myself going anywhere near full throttle.
12-17-2018, 03:04 PM | #45 | |
