Old 06-18-2018, 02:08 PM   #1
vet_stingray   vet_stingray is offline
I broke the chain tightening bolt
How would I go about repairing this. 2016 200 Denali/ Tmec
File Type: jpg 5DBB7B67-E90C-4AB1-BC7E-BAEA4CD4BDC2.jpg (13.5 KB, 400 views)
File Type: jpg 65C97693-D815-41CA-BFED-6BF7189385C2.jpg (14.2 KB, 397 views)
Much Rather be ridin
Old 06-18-2018, 02:54 PM   #2
I wonder if the Hawk/TT250 adjusters are the same dimensions? If you can measure the inside of the swing arm tube I can see if it matches my Hawk. If so, then you can order a set from CSC for the TT250. Unless somebody can provide a link to your specific part, it is at least an option.
This is each, so if you want two, make sure you set the quantity to 2. http://www.cscmotorcycles.com/TT250-...p/zt26-107.htm
Old 06-18-2018, 07:24 PM   #3
Thank you I’ll be sure to measure and check it out tomorrow
Old 06-18-2018, 09:55 PM   #4
pistolclass's Avatar
ok vet_stingray, what year is the chevy? I have 71 vette.
Old 06-19-2018, 10:17 AM   #5
Man I really need to change my user name I made that email when I was about 12 and I thought a corvette was the coolest car in the world I didnt realize till a few years later that I spelled vet wrong. But yeah I own no chevys but I do have a fleet of VWs
Old 06-19-2018, 10:22 AM   #6
So I found this Parts listing to Denali 200 of course I the company doesnt actually sell the parts.
https://sunright.s3.amazonaws.com/im...7.15.2015_.pdf
Have not had a chance to pull mine out to see check it against the TT250 one you posted but I may just order them and make um work. I bought my bike used I think I am going to find the guys number I bought it from and see where he got it and see if they can get parts. He bought it assembled somewhere here in GA.
Old 06-19-2018, 10:36 AM   #7
The swing arm looks to be the same as the Hawk and TT250. It should work.
2020 Kawasaki Vulcan S
Old 06-19-2018, 05:45 PM   #8
This it off the bike appears to maybe be aluminum and has a bolt welded to it so I may try to find a matching bolt and see if I can get it tacked at a local trade School. That is if I can get the original out I don’t own a dremel.
Old 06-19-2018, 05:50 PM   #9
Doh!
Pics of the part
File Type: jpg FD8B23A7-5F4B-4E4C-A497-B85834FD8019.jpg (15.2 KB, 351 views)
File Type: jpg B10D6526-BF91-48B6-BAE3-7199952A0B6C.jpg (18.1 KB, 329 views)
Old 06-19-2018, 11:53 PM   #10
The pics could be deceiving, but it doesn't look like aluminum to me. Does a magnet stick to it?
Old 06-21-2018, 11:03 AM   #11
https://www.chinesemotorcyclepartson...artno_CNADJ030
I think this may be the one has anyone ever used this site?
Old 06-21-2018, 11:04 AM   #12
Good observation I will check, I was mainly looking at how clean the tacks were. Ill check.
Old 06-21-2018, 01:39 PM   #13
You could probably use a rotary tool and cut the tack weld and just replace the bolt. If you don't have a welder you could just use a nut with a lock washer and tighten it in place.
Old 06-21-2018, 06:28 PM   #14
I found a matching bolt, tourched the old one out, ground a notch to fit the new one in, aligned it the best I could and welded it in. It was galvanized not aluminum good call. Just installed it but how do I make sure the back tire is properly aligned?
Old 06-21-2018, 06:36 PM   #15
I found this video going to gove the first method a try.
