01-16-2019, 04:19 PM | #1 |
Just installed new carb. Do I need to adjust it
Do I need to adjust the air mixture first or just try it came first? 1.5 turns? Please advise.
01-16-2019, 06:25 PM | #2 |
Try it out see what its like
01-16-2019, 11:24 PM | #3 | |
the idle mixture screw setting is whatever you need to adjust it to be. 1.5 turns out is just a generic starting point.
01-16-2019, 11:43 PM | #4 |
Mikuni VM26 30mm Carb Carburetor PZ30 200cc 250cc Fit For Honda Hawk
01-16-2019, 11:59 PM | #5 | |
Have you changed out the jets? Those come out of the box too lean for our engines, especially if you have any mods like intake and exhaust.
01-17-2019, 12:35 AM | #6 |
I put a 110 in it.
01-17-2019, 01:03 AM | #7 |
01-17-2019, 11:08 AM | #8 |
Stock
01-17-2019, 11:26 AM | #9 |
That tends to mean nothing. I will just assume it is a 20 pilot jet. In which case, it will work, but it is generally too lean. Most people end up around 2-2 1/2 turns out from lightly seated on the idle mixture with that pilot size. I recommend a 25 pilot jet. VM28/486 is the jet type.
For the main, depending on mods, a 110 may work. With intake and exhaust, a 115 is better. if you live at a lower altitude (sub 4000ft).
