Old 01-21-2019, 01:18 PM   #1
BBOWL10   BBOWL10 is offline
BBOWL10's Avatar
Hawk Rear Shock Question
I have this shock headed to me from the motherland. Is it ready to install or do I need to take it somewhere to have it charged before I put it on the Hawk?
File Type: jpg D6A21F62-D516-4E8C-8F3E-95F9F48265E6.jpg (9.4 KB, 417 views)
2017 Kawasaki Versys 650 - Seat Concepts Seat, Moto Werk Foot Peg Lowering Blocks and Highway Pegs, MadStad Windshield, SW Motech Rear Rack, Givi Handguards and Rear Fender Hugger, Polaris Series Regulator Mod, Denali Sound Bomb Air Horn, SHAD Luggage
2018 RPS Hawk 250 - CRF230 Exhaust, Mikuni Clone Carb, LED Headlight and Tail Light, Pod Air Filter, Generic Hand Guards, Volt Meter/USB Port, Grip Puppy Grip Covers, 45 Tooth Rear Sprocket, Shinko 244 Tires with IRC HD Tubes, AGM/SLA Battery
Old 01-21-2019, 02:18 PM   #2
Mine came charged, but as with anything from that part of the world for that price point, it doesn't hurt to check lol.
Old 01-21-2019, 03:08 PM   #3
BBOWL10's Avatar
Megadan,
Will I be able to readily tell if it is precharged when I get it?
Old 01-21-2019, 04:20 PM   #4
Originally Posted by BBOWL10 View Post
Megadan,
Yeah, it should be obvious once installed. With little or no pressure the shock will be as useful as a marshmallow. A pressure gauge can also be used.
Old 01-23-2019, 01:02 PM   #5
BBOWL10's Avatar
Megadan,
What PSI are you running in your shock?
Old 01-23-2019, 03:28 PM   #6
Megadan,
I left it with what it had for a charge when I got it, which was only about 60psi. I haven't had a chance to ride it on anything rough enough to know if I should adjust it from there. Most rear shocks run well above this (usually double or more), but given the nature of these shocks - where they come from and no reservoir - I am hesitant to go as high as some other shocks are capable of. Once the weather warms back up I am going to slowly add pressure 10psi at a time, to see how it does.
Old 01-23-2019, 05:31 PM   #7
Mine came with a charge and is 1000 times better than the stock. You'll be happy.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 01-24-2019, 04:22 AM   #8
pete   pete is offline
pete's Avatar
most shocks are around 140psi of nitrogen ..
they are pre filled and non adjustable for psi...
air valve on the shock seems to be a Chinese thing...good selling
point for the uninitiated which is the Chinese market to most existent..
gimmicks / bling and cheap sell...
there were a few jap shocks with a air valve and internal bladder...
LOL.. I have just ordered a set of Chinese Ohlins copies...
look identical to Ohlins TTX... but the compression adjusting nob
is stuck on for looks and dosnt even turn.. lol
toss some Ohlins stickers on them... Who will ever know I'm a cheap bastard..
They will be Ok for a 1980 KL250..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
