03-03-2019, 12:46 PM | #1 |
HAWK 250 Instrument Cluster Where?
Where can you get the RPM digital instrument cluster these days for the HAWK 250?
03-03-2019, 12:54 PM | #2 |
Just got a fresh shipment in. E-mail me @ hawkclusters@gmail.com for info. Thanks!
03-03-2019, 01:33 PM | #3 |
Right There ^
03-04-2019, 01:15 AM | #5 | |
03-04-2019, 02:35 PM | #7 |
Trail Tech Vapor is also another option... unless you really needed a "fuel tank gauge" or something silly like that... I mean, hell, you are already looking at spending 100$ or so on some of those other digital clusters, why not just get a "Name Branded" one
03-06-2019, 08:37 AM | #9 |
https://www.ebay.com/itm/Universal-N...YAAOSw39FayyXj
Guitar guy. I have the same one and was wondering how you hooked up your speedo cable or if the stock cable plugs into it? My hawk front disc does not have a place to drill a hole to add the magnet. Any clarification and pics on how you did it would help tremendously! |
03-06-2019, 09:26 AM | #10 | |
03-06-2019, 11:43 AM | #11 | |
Okay my bike is a hawk and if you look at the brake rotor from the right hand side you'll see that the very inner hole of the holes drilled in the rotor never passes through the brake pads. So I drilled two holes in inserted magnets it was the perfect fit as far as the thickness. Now on the other side I didn't take a picture cuz I haven't installed the pick up yet I'm waiting on a tap. Cuz my plan is to drill and tap the brake caliper bracket where the magnet passes underneath it and screw the pick up into the bracket and lock it with the nut that's on it cuz I felt if I drilled a hole through the bracket and did a nut on each side it would be too close to the magnet passing by. I also had trouble accessing my menu within the speedometer to change the calibration my instructions were wrong that came with it. But I found the correct ones on the internet hope my tap shows up soon can't wait to finish this |
03-06-2019, 12:12 PM | #12 | |
This is the one that I bought there are several different versions of it usually having to do with the gear shift indicators which the hawk does not do the only thing that works is the neutral light hope this helps |
03-06-2019, 01:39 PM | #13 |
I can confirm that idea works, use an empty hole and a marker to find the path on the bracket. I used Red thread lock on the sensors threads.
03-06-2019, 01:50 PM | #14 | |
03-06-2019, 02:22 PM | #15 |
No kidding.. sweet. Thank you
