Old 05-15-2019, 06:11 PM   #1
Orndorf   Orndorf is offline
Is the 2018 kymco like 200i restricted ?
I can only get my 2018 kymco like 200i speedometer up to 60mph, is this normal ? Is there a way to derestrict it ?
Old 05-15-2019, 07:19 PM   #2
ben2go   ben2go is offline
Yes and no. To pass emission to get into certain areas of the world, the bike is running very lean. A good aftermarket exhaust and air filter along with proper jetting will bring the power back. Also, adjusting the valves as they're not usually in spec from the factory. Running these engines lean for to long will cause them to burn valves and pop pistons.
Old 05-15-2019, 08:02 PM   #3
humanbeing's Avatar
Originally Posted by ben2go View Post
...with proper jetting will bring the power back...
Kymco model w/ i means "electronic fuel injection" Unlike good old carb model u can't tune it unless rewrite data (PiTA & costs $$$) to it.
The 1st thing u can do is check the valve clearance. Next is check the belt's condition...
Old 05-15-2019, 09:13 PM   #4
wheelbender6's Avatar
Some slider weights and an adjustable wind screen may get you a few more MPH.
Old 05-16-2019, 05:03 PM   #5
Doh. I had to look it up. I was thinking of a different moto.
