06-10-2020, 11:30 AM | #1 |
Crf230f cylinder in an X31?
I'm having a hell of a time finding top end parts for my X31.
ZA169FMM, more like a 65mm bore with 15mm pin. It looks like the valves are the same dimensions as the crf230, so I ordered seals from Honda already. |
06-10-2020, 01:50 PM | #2 |
Yep, it should work. You'd be the first on here to do it though, so make sure that you document it!
06-10-2020, 02:07 PM | #3 |
I recently installed the CRF230F Wiseco 11:1 piston on my X22R 250. It's a 65.5mm bore with 15mm pin.
06-10-2020, 02:19 PM | #4 |
The CRF230F Big Bore kits and cams will also work on these engines. https://www.ebay.com/itm/Athena-67mm...2228ab027919bc
06-11-2020, 10:24 AM | #5 |
I see a bunch of pistons sold as 65.5mm of, do you guys think it means they are actually 65.5mm of or they are meant to for a 65.5mm cylinder??
06-11-2020, 10:30 AM | #6 |
They are meant for a 65.5mm bore. I don't remember the exact measurement but the piston is slightly smaller.
06-11-2020, 12:47 PM | #7 |
Mine is like 64.98mm.
06-11-2020, 01:28 PM | #8 |
Stock piston on a 65.5mm cylinder would be around 65.49-65.47mm. Service limit is 56.40mm.
Did you measure the bore of the cylinder?
06-11-2020, 04:51 PM | #9 |
Yea the cylinder is 65.5 top, bottom and middle.
06-11-2020, 04:54 PM | #10 |
So yeah that piston is worn out at 64.98mm.
06-11-2020, 09:24 PM | #11 |
From CRF230F shop manual:
Measure at the gauge point w/ correct tool & not as these http://www.chinapartsdepot.com/shopp...exd.asp?id=771 clowns as possible === The average Chinese Joe will just put another 67 BBK https://item.taobao.com/item.htm?id=617131505511 when worn. Anway the standard 65.5 chonda nowadays is using [0.8/0.8/2.8]. Why such 2.8 oil rings cuz there's history reason https://motorcycle.sh.cn/thread-17320800-1-1.html (Change to destop mode if via from mobile device) Suzuki F10A (& copycats) 2.8 really works unlike the bike specfic thin rings they failed to copy ...
06-11-2020, 09:52 PM | #12 |
Yea, 0.52mm clearance is double what it needs to be.
I have a new piston coming. Bore seems alright. Once I get the new valve seals and piston installed and the bike running, I'm going to order a crf230 big bore kit whick I think is about 67mm, and they come with a domed piston. But I just want to get back riding asap. |
06-12-2020, 07:40 AM | #13 | |
Here's a link to the CRF230F shop manual. https://www.google.com/url?q=https:/...91965565636000
06-12-2020, 10:00 AM | #14 |
How old is this bike? A piston that worn out would likely not run in the engine, I've never seen one wear out a whole half mm. The piston/cylinder would look pretty gnarly if it was that much worn out.
06-12-2020, 10:05 AM | #15 |
I was thinking the same thing. A new cylinder and piston would be the way to go. Might as well do the BBK.
