08-13-2020, 08:40 AM | #1 |
front sprocket bolts
....so while taking a short ride yesterday on my tbr7 my front sprocket bolts were evidently loosening and gave up leaving me at the side of the road about 2 miles from home
.....after a fair amount of coasting downhill (and pushing up hill ) i got the bike home and pulled the front sprocket cover off to find no sprocket at all and no bolts... where can i purchase the bolts (and the retention plate aka fixing platetoo) and is there a better part available like maybe a actual Honda part? obviously i will be using some loctite this time :doh thanks and cheers
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 Last edited by Kenstogie; 08-13-2020 at 02:07 PM. |
08-13-2020, 02:03 PM | #2 |
i understand CSC stuff fits the hawk which probably is the same as tbr7 and they have them... are they the same? maybe.... guess i will find out.... i ordered a fixing plate and the bolts.... i have a jt 17 tooth that i was going to put on there any way so.... fingers crossed
https://store.cscmotorcycles.com/TT2...HAFT-s/321.htm
08-13-2020, 02:09 PM | #3 | |
08-13-2020, 04:39 PM | #4 |
08-14-2020, 11:27 AM | #5 |
i did order from csc but not entirely sure they ship all to quickly and wanted to ride sooner than that soooo i think i may have found another source.... with way quicker shipping... havent tried it yet but is on its way..
https://www.amazon.com/DSparts-Teeth.../dp/B07KTYLP98
08-14-2020, 01:18 PM | #6 |
Kenny could you hit your local hardware store and grab 2 M6x10mm bolts and test fit?
08-14-2020, 01:53 PM | #7 |
But he's missing the entire sprocket too. Must have fallen off and out.
08-14-2020, 04:40 PM | #8 |
Loctite - your friend.
08-14-2020, 06:11 PM | #9 | ||
Gospel for sure... funny I didn't loctite (so mandatory) those but did most others when I assembled it... I also have discovered the nuts and bolts are metric (ish) and my sae stuff fits some stuff better...
08-14-2020, 07:08 PM | #10 | |
If loctite isn't a good option, at the very least some lock washers under the bolt heads will do the job too.
08-14-2020, 11:31 PM | #11 |
Funny thing about this thread... although I have essentially painted my TBR in loctite from head to toe... I DEFINITELY missed those little suckas when I upgraded to a 17 tooth
08-15-2020, 08:08 AM | #12 | ||
if you happen to know of any good assortment packs of metric nuts and bolts please let us know because my local hardware store single prices are nickel and diming me (and probably everyone else) to death
