Old 03-21-2021, 01:42 PM   #1
idle_purr   idle_purr is offline
idle_purr's Avatar
Trouble getting neutral
Hey guys, I have been breaking in the Brozz today and just noticed for the first time that I am having trouble up shifting into neutral. I know it can sometimes be tricky going up or down the half gear but my digital cluster is even indicating I am in the neutral position, though the bike still has a friction point as if it's in 1st and if I let off the clutch it rolls forward and stalls.
Any ideas?
I am still using the break in oil that came with the bike, will be changing to 20W50, not sure if that could help, or if there were any adjustments that can be made.
Thank you!
NO HILL TOO STEEP NO MUD TOO DEEP
The Brozz | The Hawk Upgrades, Accessories, Etc...
Assembly Checklist: Brozz 250 | Hawk 250
~idle_purr
Old 03-21-2021, 02:42 PM   #2
Bill Hilly   Bill Hilly is online now
My bike has gone into neutral easily since I got it,. But I remember as a kid on our dirt bikes, we would kind of rock them a little as we tried shifting to neutral. We didn't have indicator lights . I hope it gets better ad you break it in.
Old 03-21-2021, 03:00 PM   #3
Oldwolf   Oldwolf is offline
Oldwolf's Avatar
On my bike neutral has a long engagement point, its gotten easier as she's broken in. But its tough to find right at first. Your gearbox will loosen a bit and it gets easier.
Old 03-21-2021, 03:03 PM   #4
idle_purr's Avatar
I have always rocked them as well when the vehicle was off, but this is taking place while the engine is running. Usually when pulling into my driveway, I will down shift into neutral and let the engine idle a little before shutting it off. The bike feels as if it shifts into neutral, and the cluster shows the green N, however sometimes the clutch will still grab.
I am hoping that as the bike breaks in everything will work correctly.
~idle_purr
Old 03-21-2021, 03:28 PM   #5
TxTaoRider   TxTaoRider is offline
Check your clutch adjustment.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 03-21-2021, 05:42 PM   #6
BuffaloChinaRider   BuffaloChinaRider is offline
Its because bike is still new, put some miles on it and also put normal oil in it instead of leaving whatever they have in there. Many of the bikes hit false neutrals as well when they are brand new. Change that oil and give it some break in miles, it wilL get better.
BuffaloChinaRider on Youtube
Bashan Storm 250 (2018)
Apollo Db-36 Deluxe (2019)
Old 03-21-2021, 06:54 PM   #7
Spins   Spins is offline
Spins's Avatar
It will get better as it breaks in . My Recon is the same way right now. Clutch adjustment is also probably needed. As these bikes heat up it seems if the clutch isn’t adjusted just right it causes a shift issue. I’m seeing false neutrals too. Planning on changing the break in oil soon, this will help.
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 03-21-2021, 08:25 PM   #8
Boatguy   Boatguy is offline
Boatguy's Avatar
Totally different bike, same exact problem.
Neutral is a tricky find on mine also. I have found a trick that seems to work. At least 90% of the time. Shift down to first, then back up to second, and then a little half shift down to find neutral. Mostly works on my bike.
Going from first to neutral is pretty much a no go with my bike. I have about 250 miles on it right now. I’m on my 2nd quart of break in oil.
2020 Lifan x-pect
Old 03-21-2021, 09:52 PM   #9
RussellTA   RussellTA is offline
RussellTA's Avatar
Exactly the same method as my XPect at 300 miles. Once I figured out to go down from 2nd it’s no biggie anymore. Hopefully another oil change will improve it
As you travel down the road of life, keep your eye upon the donut, not upon the hole
2020 Lifan X-Pect 200efi
2005 Harley Davidson Sportster XL1200R
Old 04-02-2021, 06:02 PM   #10
idle_purr's Avatar
Just giving an update, my bike now has 40 miles on it with 20w50 oil in it. It runs and shifts smooth, I never have any issues with false neutrals or finding neutral with my half shifts.
I guess it just took a little bit of riding to clear up
~idle_purr
Old 04-03-2021, 09:14 AM   #11
Boatguy's Avatar
650 miles on mine. No improvement. Maybe just a little.
Planning to change to the regular oil next. I’m still on 15w40 Rotella T3 break in oil.
What’s the collective wisdom say about the next oil to use, with a nod to this pesky non-neutral finding issue.
I should note also, it finds neutral just great when I’m trying to accelerate quickly off a red light at an intersection. In those cases it goes 1st(clutch)-> neutral(redline)(clutch)->2nd, etc etc. pretty embarrassing. Looks and sounds like I messed up, but it goes into neutral instead of second when I’m working up from first at a stoplight sometimes.
2020 Lifan x-pect
Old 04-03-2021, 10:02 AM   #12
idle_purr's Avatar
I have 20w50 Valvoline in my Brozz an 20w50 Amsoil in the Hawk.
It definitely seemed to make a difference in higher quality.
~idle_purr
Old 04-03-2021, 10:36 AM   #13
Boatguy's Avatar
And you’re still in break in. By quite a bit at 40 miles.
I’ll give the Amsoil a shot. Thanks!
2020 Lifan x-pect
Old 04-03-2021, 12:47 PM   #14
idle_purr's Avatar
Yeah I changed the oil early just for peace of mind @ like 20 miles... I have more time than miles on my bike, a lot of engine run time in the woods and stuff aside from just cruising. I make my bike sound old haha but it's still a spring chicken.
~idle_purr
