Old 12-10-2022, 09:52 PM   #1
jc3   jc3 is offline
delete
delete
Old 12-11-2022, 07:32 AM   #2
cheesy   cheesy is offline
cheesy's Avatar
If the pads are not retracting fully, it means that there is either too much brake fluid in the reservoir of the master cylinder or the fluid relief hole in the master cylinder itself is partially blocked.
You should NEVER use anything other than brake fluid to avoid contaminating the system. No oil.
Use something like a new turkey baster or a syringe to remove excess brake fluid from the reservoir.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 12-11-2022, 08:06 AM   #3
Best and easiest way to change front and rear brake fluid is using a fluid extractor.. just time it so you keep adding new fluid while it's being sucked out without bottoming out the fluid in the reservoir. Once you see clear fluid in the extraction tube, make sure its topped off and then tighten the nipple and your golden.
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 12-12-2022, 06:19 AM   #4
buzz   buzz is offline
Hello I agree with cheesy, and he knows china bikes very well. Good luck!
Old 12-12-2022, 10:42 AM   #5
cheesy's Avatar
I haven't had a China bike for a LONG time but I do know about hydraulics. And brake systems are mini hydraulic systems.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 12-13-2022, 12:23 PM   #6
Originally Posted by jc3 View Post
Front break seems to be gripping too much and not allowing the wheel to spin freely. How do I adjust the grip? The manual just has information on tightening it. The adjustment is all the way out.
Have you relieved the tension?
****The master cylinder at the lever (handlebar) is NOT adjustable. The adjustment is for setting the lever at a comfortable position (I like the levers closer to the handlebar myself).
It would not be a bad idea to just bleed the brake (at the caliper down on the wheel). It is possible that one or both of the pistons at the caliber are not retracting properly. Start with a bleed...
Put a 1/4" tube on that nipple. This will help prevent air from getting back into the caliper while you bleed it (in the pic, I have an 8mm box end wrench on the bleeder nipple). It is standard lefty loosy. BUT, do not open the bleeder valve unless you have someone squeezing the lever. AND TIGHTEN THE BLEEDER valve before releasing the lever (or air will enter thru the bleeder valve into the pistons at the caliper!). Repeat this a few times.
Most people have the opposite problem (air in the caliper pistons reducing the quality of brakes!).
