01-24-2023, 11:32 PM | #1081 |
Thought I would post pics of a Templar x cat slit open and removed I found on FB. That thing has got to be restrictive.
22 Templar X 250 Hand Guards Custom Graphics Pro Taper Grips 125 main 45 pilot jets 42 tooth rear sprocket 2010 Yamaha Vstar 1100 Silver Star |
01-25-2023, 12:38 AM | #1082 |
They're rarely as restrictive as everyone thinks they are but removing it might free up a horse. More with a cam, porting, etc. I like the way it was done with a single cut. It makes it so much easier to keep perfect alignment when welded back together. Looks like I need a MIG welder and some practice pipe.
22 Templar 250 |
01-25-2023, 01:51 PM | #1083 |
Whether it winds up being 1hp or 2hp from removing that cat, it is definitely felt in the seat of the pants as i can attest when the pipe was replaced on my Brozz. I look forward to doing it on the TempX.. wish they had a replacement header that fit on Amazon
01-25-2023, 02:32 PM | #1084 | |
01-25-2023, 02:53 PM | #1085 |
I'll defer that to our very own MegaDan who can hopefully chime in walk us thru those hypotheticals with real world experience..
01-25-2023, 03:00 PM | #1086 |
The replacement carb listed in the Templar 250 resource guide is not available for purchase on Amazon, and it's a 30mm. Wouldn't the carb I have listed below be the better choice? It is a 28mm (just like the stock Templar 250 carb) and it's available for purchase:
https://www.amazon.com/Keihin-KIMISS-Carburetor-CR80RB-1996-2002/dp/B07H6L1GWV/ref=sr_1_14_sspa?crid=F3VN0W37NV2&keywords=youall+ 28mm+carb&qid=1674676612&s=automotive&sprefix=youa ll+28mm+carb%2Cautomotive%2C84&sr=1-14-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzMkpXU 1BXRURKODk2JmVuY3J5cHRlZElkPUEwNzg0MzExMzBRNlVLVjk yNE9HUCZlbmNyeXB0ZWRBZElkPUEwMTY4ODcxMlFTQVVVV1MyV ktGUSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWR pcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= |
01-25-2023, 03:57 PM | #1087 | |
01-25-2023, 06:03 PM | #1089 |
Nix on the pod filter idea
I have seen posts here where people ask if anyone has tried a pod filter on the Templar X. I don't know about the Templar and Templar M, but the carb on the Templar X aims at the rear shock spring, and there just isn't any room for a pod filter.
But, the snorkel has a nice smooth internal surface that snakes around to a VERY LARGE opening with a BIG OILED DOME FILTER. I don't think a pod filter would be better even if you COULD get it in there! In fact, a pod filter might be more restrictive. That dome filter offers a lot of surface area and it is very porous. Air must flow past that dome filter quite freely, and the large surface area allows for good filtering as well. I think the answer is to keep the dome filter clean, and replace it if it gets too fouled to clean. If you install a different carb, good luck on mating the snorkel. If you changed your carb, have you got a picture of this???? |
01-25-2023, 08:07 PM | #1090 |
Below is the windshield I'm thinking about getting. I want something minimal--similar to what you see on KTM and Honda Rally. Ebay link below.
Here's a link to it on Ebay: https://www.ebay.com/itm/18566811144...MakeTrack=true |
01-25-2023, 08:12 PM | #1091 |
If you get it be sure to post up pics installed.. Here is what i had installed in the past on my son's Brozz:
Motorcycle Small Windshields,Universal Windscreen Wind Defector w/Mount Bracket Fit 5 to 7" Round Headlights,for Yamaha Suzuki Kawasaki Triumph Ducati Chopper Cruiser(Black https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
01-26-2023, 06:41 PM | #1092 |
Air/fuel mixture screw location?
Is the mixture screw hiding behind the silver cap that is between 7 and 8 o'clock from the idle screw when looking at the carb straight on?
Thanks in advance |
01-26-2023, 07:38 PM | #1093 | |
All: Over on thumper talk someone claims that one of the headers off of a “250R” will fit the Templar-anyone else verify that?
01-26-2023, 10:56 PM | #1094 | |
01-27-2023, 11:25 AM | #1095 |
Hey Okierider. I’m embarrassed to ask. But where is the fuse box?
