09-17-2023, 03:17 PM | #1 |
Stonemen for Temp X ??
Has anyone tried to install a stonemen exhaust system on the Templar X?
The one I am talking about is for a CRF150F CRF230F 2003-2013. It's under $100. Basic fit? Mods? Maybe this fits the CG clones, but not the 249cc 172FMM engine.
09-17-2023, 08:22 PM | #2 |
Definitely interesting. I see another ad there where they say it also fits a Hawk 250 and TBR7. Pretty sure the doesn't translate to fitting a Templar X but you got me wondering how close one might be too. I haven't cut my converter out yet. Wouldn't bother me much to be lazy and just swap pipes instead.
https://www.amazon.com/Exhaust-Muffl.../dp/B01DO6IBLQ |
09-17-2023, 10:59 PM | #4 | |
I am thinking this would fit my CG250 ZS167-FMM in the Storm nicely. But I already did a cat delete on that bike and drilled the exhaust. It won't make more than 15 hp without head work lol
I am sure there is a header for the 172-FMM. Must be. Quote:
09-17-2023, 11:14 PM | #5 | |
Doesn't that stoneman pipe have a cat? If not what's the bulge for?
22 Templar 250 |
09-18-2023, 11:02 AM | #6 |
No,it's not a cat. It's a "power bulge" - aka an expansion chamber. An attempt to alter the resonant frequency in the exhaust pulses to try and improve scavenging for better power at a certain point in the RPM range.
09-18-2023, 12:02 PM | #7 |
No it's not my weld, I was able to have it done at work, I separated using a tubing cutter, if I could do it again I would use an angle grinder with a .045 cutoff wheel
