04-24-2009, 03:19 AM | #1 |
Bits in the oil, Again!
When I arrived home from work this morning I decided to change the oil as it had been in nearly 2000km. What do I find? Redish brown rubber flakes on the strainer. It's not the crush drive again as the rubbers are black. If I remember correctly the timing chain tensioner blades were black as well. To be honest I can't be bothered with it, I have house repairs to get on with, and a semi classic motor car that wants attention.
Jonathan. |
04-24-2009, 10:56 AM | #2 |
Two good things about that:
The strainer is doing its job. The particles aren't ferrous.
04-24-2009, 11:29 AM | #3 |
What's the car ?
Happy to serve. |
04-25-2009, 03:43 AM | #4 | |
As for the rubber bits I'm tempted just to ride it and see what happens. Jonathan. |
04-25-2009, 11:29 PM | #5 |
Hmmm, well it "could" be seal material, or, it might be something coming from the carb manifold. Sure its not black plastic and not black rubber?
Seer
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
04-26-2009, 03:30 AM | #6 | |
Jonathan. |
