11-29-2009, 09:42 AM | #1 |
GIO Monster: Which belt?
I recently purchased a GIO Monster replacement motor, it was cheap, the shipping was not........anyway.......
The drive belt is a 743.20.30 (length.width.angle) Gates # PL30707 I will be heading into the final drive and will report on the final drive ratio. The final drive ratio (13/40) appears to be 3.07:1 I have no idea what a "normal" ratio is? I see gears listed from (14/39) 2.78 to (17/36) 2.11 for scooters. |
11-29-2009, 05:46 PM | #2 |
Are you referencing two final drives, meaning the gearbox and the chain? I presume that there is a gearset in the box that multiplies torque, since scooters mount the rear wheel directly to the output shaft.
11-29-2009, 07:13 PM | #3 |
I'm speaking about the final drive gear set in the transmission. (I'm in here removing the brake anchor pin block-off plug and installing a brake anchor pin)
http://www.partsforscooters.com/Vehi...e/Transmission Specifically gear #6 that fits on the output shaft/axle being 40 teeth and the counter shaft gear #7 of 13 teeth that is the driver of #6. The ATV/Buggy has a final drive ratio (in the transmission) of 3.07:1 I am working on finding out the final drive ratio for scooters (there is a range of 2.57:1 to 2.11:1 available), so far I have been told that something around 2.375:1 is not uncommon (16/38 ), giving around 7200 RPM @50mph. |
11-30-2009, 01:56 AM | #4 |
Are you planning on installing the GY6 in a scooter (hence the brake anchor pin)?
11-30-2009, 02:09 AM | #5 |
yes
11-30-2009, 02:40 AM | #6 |
Was it a 150cc scooter to begin with?
11-30-2009, 02:56 AM | #7 |
Not likely. There are certain advantages to doing a re-power of a small displacement scooter/moped. This motor was bought cheap and I'm getting it ready to install into something. I have, at the moment, a 50cc yamaha, that needs a complete re-fresh (in the spring), it may go there, or I might buy something. At the moment it is something to work on when it's raining, or snowing, when I have time available in small blocks. |
11-30-2009, 11:26 AM | #8 |
Please keep us updated as you make progress.
My buddy and I have tossed the idea around of installing a GY6 into an old BW. It looks like a fun project, and there's always room for mods. It's quite remarkable how many speed parts are available for the GY6.
11-30-2009, 12:33 PM | #9 |
Truthfully a GY6 is wasted in a BW. It's not too difficult to get 6-12hp out of a BW, mine, sick as it is, still hits 50mph (with my fat ass on it). The idea here is to do it to something slow, maybe a Razz, or a Hobbit.
That said........ A GY6 is almost a direct fit into a horizontal BW (02 and later), with only washers needed to shim the motor mounts (the vertical BW will need some frame mods), the electrical system needs a relay added for shut-down. A short case is a direct fit, a long case motor will require some messing with the shock, either relocation, or longer. |
11-30-2009, 04:13 PM | #10 |
My buddy has an '07 Aprilia that'll do about 95km/h with him on it, but I really like his fat 150 Mojito; nice ride.
I think that my buddy still has a pre-'02 BW Leo Vince available for sale; do you have any interest in it? Thanks for the post-'02 tips. I think that's the BW my buddy has, and it's a perfect candidate because it was a wreck.
12-02-2009, 08:18 AM | #11 |
Yes, but...........
The GY6 motors we are buying are maybe 8hp, unless you buy a "4 valve", or a "big valve", there should be little trouble getting more out of the 2 cycle engine. Your typical 8hp GY6 engine is $299US, at least $100 to ship, a wheel, bits, and pieces another $200 (I'm going easy here, $300 is more realistic). $600 will mod that 2 stroke engine to about 12hp, and last 2 seasons between re-builds, and you have a reasonably stock scooter to sell (higher value). If you do a re-power of a "nothing", you still end up with "specialty build" that has only the value of the build in it. (02 or newer BWs bring $1500+ out here in nice shape stock) |
12-02-2009, 08:29 AM | #12 |
Please let me in on what a BW is?
12-02-2009, 11:30 AM | #13 |
A BW is a Yamaha 50cc scooter. It is often referred to as a "Big Wheel", as the wheels are quite fat for the overall height.
12-02-2009, 03:50 PM | #14 |
A "Zuma" to you US folks.
