Old 03-14-2010, 01:35 AM   #1
garage187   garage187 is offline
Anyone know what parts interchange from a honda to lifan 200
looking to buy a performance cam but i can't find any ..
Old 03-14-2010, 01:37 AM   #2
Welcome!
I wondered the same thing for an XR200R that I'm building for my son. I think that the only option is to have the cam reground; there are two cam grinders in my area, but I wasn't prepared to pay the cost.
Old 03-14-2010, 01:38 AM   #3
i heard the xr cam will work in the lifan. and that it's supposed to be bigger.but i dont know for sure
Old 03-14-2010, 01:44 AM   #4
You could always check for yourself, if you could find a used one at a local bike wrecker. You could spin the cam in the bearings and check it with a cheap dial indicator and compare it with the Lifan cam. You could then install it and check for piston to valve clearance with your preferred method, although I think that clay would be the most foolproof.
Old 03-14-2010, 01:47 AM   #5
there's no bike junkyards here and the specs i need i can't find online.
Old 03-14-2010, 01:52 AM   #6
what about akunar camshafts??or what if i swap a cam from like a 125cc lifan.will that work?
Old 03-14-2010, 03:19 AM   #7
I don't know. What if you tried to pick up a cheap XR200R cam on eBay?
Old 03-14-2010, 03:30 AM   #8
someone out there has to know. i like to find a big bore kit to. anyone got a xr cam i can buy or messure?
Old 03-14-2010, 01:47 PM   #9
I don't see how it could work. The Lifan is OHV, the Honda is OHC. Different animals.
Old 03-14-2010, 02:37 PM   #10
katoranger's Avatar
Is the lifan engine an OHC engine? Some are pushrod. W&G might have one out the could be measured. Otherwise you may be able to buy a used one off ebay for testing purposes.
Allen
Old 04-15-2010, 02:49 AM   #11
I measured two XR200 cams tonight: http://www.chinariders.net/modules.p...&highlight=cam
Old 04-15-2010, 09:21 AM   #12
katoranger's Avatar
I may be willing to open up the GS200 engine I have here to do some measuring.
W&G, I am no engine expert. Would you tell me what I need to measure?
I believe my buddy has some calipers and dial indicators.
Allen
Old 04-15-2010, 11:25 AM   #13
To make it simple, I'll respond here: http://www.chinariders.net/modules.p...&highlight=cam
