Old 07-04-2010, 04:47 PM   #1
DanteSD   DanteSD is offline
Giovanni 125cc - Best Carb ?
What would be the best carb for my gio, i was looking into the mikunis, would this be a good buy?
Old 07-04-2010, 06:45 PM   #2
waynev   waynev is offline
I actually found the stock carb to do a really good job, always started 1st kick, idled fine and had no hestitation up and down the rpm's, i had the mikuni upgrade carb but never found the need to install it.
Old 07-06-2010, 02:06 AM   #3
boost_addict   boost_addict is offline
have you modified anything else?
Theres no point in putting on a bigger carb if the rest of your engine is stock.
If you decide to port it out and are getting a bigger manifold, cams, exhaust, etc. then the mikuni 26mm I have on my bike works awesome!
